Date/Time: Wed, 25 Nov 2026 21:36:00 +0000
VBP based on Recent bid/ask
View Count: 784
[2025-05-21 08:53:31]
User981449 - Posts: 52
Hi, please is it possible to have a VBP study (diff bid ask) based on Recent bid/ask?
[2025-05-21 12:52:50]
User135243 - Posts: 337
Go to Volume Bar Calculation and change "Total Volume" to "Ask Volume -Bid Volume" and it should show the Delta (I'm not sure if you mean that, but I guess)
[2025-05-21 13:04:56]
I was looking to create a dynamic vbp based on Dom Recent bid/ask
[2025-05-21 13:29:40]
ah ok, I guess this will be difficult, because a volume-profile is based on executed orders (that's why it is called volume-profile), recent bid/ask are not filled limit-orders. I'm sure someone from support will have a better answer :) (if this is possible)
[2025-05-21 14:57:59]
This is not supported using the built-in tools. You would need to create a custom study to do this. Refer to the following:
ACSIL Interface Members - Functions: sc.GetRecentAskVolumeAtPrice() / sc.GetRecentBidVolumeAtPrice()
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
