Date/Time: Wed, 25 Nov 2026 21:35:54 +0000
SPX_CGI Disappeared
View Count: 955
[2025-05-21 03:28:23]
goodthinkin - Posts: 8
I have SPX_CGI add to an ES chart using the ADD ADDITIONAL SYMBOL study. I keep it hidden most of the time and mostly run calcs off of it.
Something was off so I un-hid it today and found it missing. I have gone through the steps to delete and redownload all data but that didn't bring it back up.
Suggestions?
[2025-05-21 14:08:19]
Open a standard chart for SPX_CGI and see if the data is showing properly in that chart.
If it showing correctly, then check the scale for the "Add Additional Symbol" study and make sure it is set to "Automatic" and then reset the scales. Refer to the following:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
Chart Scale and Scale Adjusting: Resetting the Scale
[2025-05-21 16:48:56]
SOLVED. NICE! Thank you!
It was the scale. I am so used to making all my studies "same as region" I just naturally set em up that way.
Cheers!
