Date/Time: Wed, 25 Nov 2026 21:35:55 +0000
How to Enable Automatic CSV Export for Spreadsheet Study
View Count: 2525
| [2025-05-20 22:31:34] |
| User997755 - Posts: 10 |
Hi there, I'm using a "Spreadsheet Study" on one of my charts (via Analysis > Studies > Spreadsheet Study), and it’s working fine. I see the sheet updating in real-time (like Signal.scss), and I want to use that data in another program. From what I remember (or saw in docs), there used to be a setting like: “Save Spreadsheet Studies as CSV Files” under Global Settings > Spreadsheet Settings. But I don’t see that option anywhere in the current version (v2758 64-bit). So I just wanted to ask: 1. Is there still a way to have the Spreadsheet Study auto-save to a .csv file? 2. If so, where do I enable that? 3. If not, is there any workaround (config file, scripting, or whatever) to do it? Appreciate your help — just trying to get real-time output from the Spreadsheet Study into a .csv file reliably. Thanks! Date Time Of Last Edit: 2025-05-20 22:34:47
| [2025-05-21 13:57:19] |
The option to save the spreadsheet to text is still there. Refer to the following: Spreadsheet Study Inputs: Periodically Save Sheet as Text in Seconds For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
