Date/Time: Wed, 25 Nov 2026 21:46:11 +0000
Cumulative delta bars trades and kagi charts
View Count: 803
[2025-05-19 02:18:50]
doctor10 - Posts: 88
The cumulative delta bars trades do not draw as candlesticks when using kagi study. What can I do to correct? tnx
[2025-05-19 15:23:20]
Are you trying to base a Kagi Chart study on a "Cumulative Delta Bars - Volume" study? If so, then this will not work.
The Kagi study needs to access the underlying data that makes up the bars. This is not available when using a different study. Therefore, it is not possible to base the "Kagi Chart" study on another study.
[2025-05-19 17:14:51]
The kagi study is on the main chart graph of ES;
when the Kagi study is active, the cumulative delta bar trades does not properly print; the cumulative delta bar volume does so
[2025-05-19 19:09:12]
Neither one is really working properly with the Kagi. The "Cumulative Delta - Volume" looks better, but it is also not correct. You really cannot use those studies when using a Kagi chart.
