Date/Time: Wed, 25 Nov 2026 21:46:13 +0000
Volume filtering on non-time based charts
View Count: 859
[2025-05-17 11:34:22]
User882351 - Posts: 8
I currently have a time-based chart open with 3 different volume studies, each one showing me volume from different sized traders:
- Volume Study 1: Filtered to show trades of 1-99 lots
- Volume Study 2: Filtered to show trades of 100-199 lots
- Volume Study 3: Filtered to show trades of 200+ lots
The way I achieved this was opening 3 additional charts and filtering the volume on them using: Chart Settings >> Data Limiting >> Volume Filter Settings.
I then used "Study/Price Overlay" to display the Volume from those 3 charts onto a single chart, as explained above.
This works great for time-based charts. However, I run into issues when using volume-based charts or tick-based charts. I have included screenshots below to demonstrate the issue I'm facing.
It would be amazing if there was a study which would allow us to filter the volume at a "study level" instead of having to filter the volume at a "chart level", and then overlay it onto a separate chart.
Private File
Private File
Private File
[2025-05-19 14:34:04]
There is no reason why the volume filtering would not work with a non-time-based chart. What you are seeing is due to a single trade occurring that takes up multiple quantities of 500. So this is correct for how you have the information displayed.
If you want to view a chart that does not split records, so that you will see 500 volume when it can, but then will show more volume if there is a single trade that is not split into smaller volumes, then refer to the following setting:
Chart Settings: Split Data Records (applies to Number of Trades, Volume and Range charts) (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
