Date/Time: Wed, 25 Nov 2026 21:46:08 +0000
Adding Draw Style Percentage/Ticks Offset to Overlay Inputs
View Count: 868
| [2025-05-16 16:19:52] |
| User273277 - Posts: 145 |
I have coloured bar studies I am overlaying as eg. dots or triangles, but the drawings are stuck in odd positions high above my candles. There's no way I can see to adjust the vertical offset of these drawings. Some studies have an Input called Draw Style Percentage/Ticks Offset. In the Overlay Study, is it possible to add the Input called Draw Style Percentage/Ticks Offset? |
| [2025-05-16 17:16:24] |
Thank you! You guys are awesome.
| [2025-05-16 17:48:03] |
Sorry - actually we were wrong in our original statement. We forgot about the "Multiplier" value that already exists in the Study/Price Overlay. Use that multiplier to adjust the data as you want it. We have removed our original response since it was incorrect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-19 09:33:30] |
| Sierra_Chart Engineering - Posts: 25483 |
If you are still not able to do what you want the fastest thing for you to do is to modify the study code at this time to meet your requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-19 09:34:14
