Date/Time: Wed, 25 Nov 2026 21:46:09 +0000
TPO Chart Column Issue
View Count: 658
| [2025-05-16 12:45:17] |
| User268697 - Posts: 4 |
Using TPO chart in 30 min time frame. (central time, US). Yesterday, 5/15/25, the J period started printing outside of the profile. It is now spread out over many days in the future, 5/15/25 to 9/19/25. It printed J's until 7/17, skipped to 9/8, then started printing the overnight session. Now printing A period, for today, on dates, 9/13 to 9/17. Advise on reset or solution. Thanks
| [2025-05-16 14:42:42] |
Refer to the following: NOTICE: NASDAQ TotalView Issue 2025-5-15, 2025-07-14 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-19 12:15:42] |
"Help>>Download Current Version" did not fix TPO chart, SPY data - solutions??
| [2025-05-19 13:40:00] |
| Sierra_Chart Engineering - Posts: 25483 |
Right-click on the chart, from before May 15, 2025 and select Delete and Download Data. This will resolve the issue. Scroll the chart back if necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
