Date/Time: Wed, 25 Nov 2026 21:46:07 +0000
incorrect time and date on horizontal time axis
View Count: 571
| [2025-05-15 20:50:19] |
| User452635 - Posts: 60 |
Dear Sir the time and date on horizontal axis is incorrect across all US Stock symbols. can you please look into it. I also tried Edit--delete all data download, but it did not work. I am attaching the message log for your kind information. thanks robin. |
| [2025-05-15 21:48:03] |
Refer to the following: NOTICE: NASDAQ TotalView Issue 2025-5-15, 2025-07-14 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
