Date/Time: Wed, 25 Nov 2026 21:46:11 +0000
Chart Linking not working when changing some values with ACSIL
View Count: 619
[2025-05-15 16:29:49]
User2069 - Posts: 34
Hi! I'm trying to change sc.TradeAndCurrentQuoteSymbol using a custom study and would like to have the change replicated to all the other charts with the same link number.
I have it properly set up in the Linking tab and it works fine when writing it manually under Symbol Settings or using the Find Symbol menu, but it does not seem to be working when changing it with code.
Is this possible with this setting? Or is there maybe a function in ACSIL for the [Apply to linked Charts] button?
[2025-05-15 17:33:36]
This is not supported and it is unlikely we would be adding support for that.
