Date/Time: Wed, 25 Nov 2026 21:46:22 +0000
Deleting a custom study
View Count: 1248
[2025-05-15 15:04:46]
Steve Leon - Posts: 319
How can i delete a custom study from the list of studies ?
Thank you
[2025-05-15 16:06:05]
If this is from a third party provider where they are setup to automatically send you the file, then you need to contact that provider and have them remove you from their list.
If this is a file that you created, or that was given to you directly (i.e. not setup to download from our website) then you just delete the .dll file that contains the particular study. Just be aware that there can be multiple studies within a single .dll, so make sure you do not delete something you do not want to. The files that contain custom studies are located in the 'Data' folder under your main Sierra Chart installation folder.
