Date/Time: Wed, 25 Nov 2026 21:46:20 +0000
Numbers Bottom alert
View Count: 605
| [2025-05-15 09:59:29] |
| rebeccaemme - Posts: 42 |
Hello, i want to out alert of number bottom when delta is more then 1900 positive or negative, so i wrote ABS (SG1) >1900 But then I want also alert for volume / sec which is visibile already on number bottom. But when i wrote then (SG36) > 5 It doesn’t work give me error formula. So i wrote on alert space ABS (SG1) >1900 (SG36) > 5 But this is error. How can I wrote correctly that? Thank |
| [2025-05-15 14:31:57] |
To start with, you can only have 1 alert formula per "window". So if you are trying to put these into a single Numbers Bars Calculated Values Alert window, then it will not work, as the following is invalid: ABS (SG1) >1900 (SG36) > 5 The simplest solution is to use an OR() statement to check either situation within a single alert. So your formula would be the following: OR(ABS (SG1) >1900, (SG36) > 5) Another solution is to use another study's Alert window, or the "Chart >> Chart Settings >> Alert" window. Put one alert condition in one of the windows and the other in the other window. Just keep in mind if the alert is not on the actual study it is referencing, then you need to add the ID of the study to the condition (such as ID1.SG36) - refer to the following: Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
