Date/Time: Wed, 25 Nov 2026 21:46:08 +0000
disfunction of an indicator
View Count: 591
| [2025-05-14 20:06:43] |
| Florian Bischoff - Posts: 10 |
Hello Sup, i got a problem by an indicator named TPO Value Area Lines. I use this one in the 1-minute intraday chart and the problem is, that the lines on the M1 doesn't match with the line inb the TPO Chart. You got a picture of it. There are 3 colors for the value area high, low and point of control. I don't know how to solve the problem, maybe you can. Thank you very much. |
| [2025-05-14 20:09:41] |
We can guarantee that if the information is setup properly between the TPO study and the TPO Value Area Lines study, then they will match up. Therefore, make sure that the Inputs between the two studies are the same. For instance, the TPO "Letter/Block Increment in Ticks" needs to be the exact same value as the TPO Value Area Lines "Price Increment in Ticks". Also the chart settings need to be the same - you can not have different Session Times or other settings that can affect the data different between the two charts, or you will not get the same answer. If you are unable to figure out what is different between these items, then get us the chartbook with those two charts in it by following these instructions (get us two charts, not just the 1 as defined in the instructions): Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
