Date/Time: Wed, 25 Nov 2026 21:46:15 +0000
candles stopped appearing on my screen
View Count: 775
| [2025-05-14 19:34:26] |
| William Cline - Posts: 22 |
candlesticks disappeared from the window in the bottom left corner when trying to use the replay chart function and wont re appear. https://www.sierrachart.com/image.php?Image=1747250986173.png |
| [2025-05-14 21:03:52] |
We see that your scale is not correct for some reason (see the value of -10737418 in the upper right hand corner). Set your scaling to be "Automatic" (if not already) and then reset the scales. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
