Date/Time: Wed, 25 Nov 2026 21:46:16 +0000
Mobile ntfy alerts impossible with Sierra running on Linux?
View Count: 590
| [2025-05-14 17:28:49] |
| juicebro - Posts: 119 |
Chat and Communications Platform: Integration with Mobile Ntfy Application 4. On the Chat window, select Commands >> Edit Chat.
I am stuck on this step. I am running Sierra on Linux/Wine. I can open the Chat Window reliably, but when I click on a chat group, the Chat Window freezes. I have seen that Sierra_Chart Engineering is aware of this below. Linux The chat is known to not work on Linux/Wine. When opened it freezes under Linux/Wine.
Is there any other way to proceed from step 4 without using the Chat Window, perhaps using a Web UI? I have no problem leaving the Chat Window minimized in the background, and then my alerts get sent to the Chat Group Web UI without freezing. It is only after opening the Chat Window and clicking on a Chat Group that Sierra freezes. |
| [2025-05-14 17:39:42] |
The only way to do this would be to setup the Chat Group using a different machine running Windows natively. If you setup your chat there, then when you open the chat for your account on the Linux system, it will have the setup done.
| [2025-05-14 18:11:21] |
Thanks that worked. For anyone else that encounters this, it was very easy to proceed with Virtualbox. I'm getting mobile alerts now while running Sierra on Linux
