Date/Time: Wed, 25 Nov 2026 21:46:13 +0000
Stop must be at or below/above last trade price...error.
View Count: 688
[2025-05-14 17:07:48]
User811567 - Posts: 8
I Checked the Chart DOM settings. I try to do sell stop then is error. I am attaching the prt sc
attachmentq.pdf - Attached On 2025-05-14 17:04:50 UTC - Size: 257.06 KB - 283 views
[2025-05-14 17:36:53]
What is the problem you are having? The image is the trades from your Trade Activity Log, which does not show any issue.
[2025-05-14 20:06:38]
When I place a sell stop order, I get this error must be at or below/above last trade price...error.
[2025-05-14 21:04:57]
How are you placing the Sell Stop order? Is this an attached order? Is this a primary order, and if so exactly what order type are you using?
[2025-05-15 05:02:53]
Everything works fine on CL, GC, only on 6E I get an error that the order must be below the last trade price(my last trade was 02.04 price was 1.08, now is far above that levels)It's primary order sell stop.
[2025-05-15 14:01:23]
Is this a case where you are trading M6E but using a 6E chart?
[2025-05-15 16:07:53]
yes
[2025-05-15 17:05:54]
Then you need to keep in mind that the price of the M6E will not match exactly what you are seeing in the 6E chart. As such, you need to adjust your Stop to be placed appropriately for the M6E.
[2025-05-15 17:32:37]
That is not the issue. Since Rithmic is being used, refer to:
Sierra Chart Teton Futures Order Routing: Using Trade Symbol
The information also applies to Rithmic.
Date Time Of Last Edit: 2025-05-15 17:32:49
