Date/Time: Wed, 25 Nov 2026 21:45:56 +0000
Control Bar
View Count: 562
| [2025-05-13 08:52:04] |
| nicktrader - Posts: 817 |
Is it possible to refer to the line “Chart Trade Settings/ General/ Display Fill Text” by using a “Control Bar” or “Keyboard Shortcut” (or similar)? Or is it possible with a customized study? Many thanks |
| [2025-05-13 13:16:40] |
That option is not available to be changed by a Control Bar or Keyboard shortcut. And unfortunately, it is not exposed through ACSIL, so you can not change it with a custom study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
