Date/Time: Wed, 25 Nov 2026 21:46:23 +0000
Shared Files (Chartbook)
View Count: 673
| [2025-05-12 19:38:07] |
| davidtrading12 - Posts: 3 |
Good afternoon, I have two computers on which I use the same SC account. Recently, someone shared a chartbook that had the same name that the one I have on my data folder on both computers. I followed the instructions and erased the previous one (had same name that the shared file) and it automatically downloaded. On the other computer I still didnt erase the previous one, so how can I download the shared chartbook? It will automatically install once I erase the previous one? Or do I have to do anything more? Thank you. |
| [2025-05-12 21:42:52] |
If that chartbook is set as a replacement for the existing one, then that chartbook should automatically download and replace the one on your system. If it is just a chance that these files have the same name, then you would need to change the name of the existing chartbook so the other one can be downloaded. You can remove the old chartbook if you do not need it any longer as well. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
