Date/Time: Fri, 16 Jan 2026 00:24:43 +0000
cannot connect to denali datafeed
View Count: 386
[2025-02-05 09:10:54]
User916807 - Posts: 12
I cannot connect to denali datafeed.
I am also using rithmic for prop firm
imagesiera connect issue.jpg / V - Attached On 2025-02-05 09:07:18 UTC - Size: 831.83 KB - 100 views
[2025-02-05 09:27:07]
User135243 - Posts: 188
Try to use another server, it seems the Chicago server doesn't work correct with SC at the moment, I switched to Europe and it works fine
[2025-02-05 09:46:47]
thank you, problem solved
