Date/Time: Wed, 10 Dec 2025 18:18:54 +0000
Eurex on Denali
View Count: 489
[2025-02-04 20:56:52]
StephenL - Posts: 122
Hi guys,
I was double paying for Eurex, once from Denali and again from my broker. So I didn't renew Denali this month and now the data doesn't update fully, in the sense that it'll update to a point then stop. Any ideas?
(and yes it is indeed CQG, and Im sure that is probably the problem, but I had to reach and check first)
[2025-02-04 22:19:28]
John - SC Support - Posts: 43402
We do not support EUREX data from any outside vendor. You need to get that data from us. Therefore, you can re-activate the exchange at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedEUREX
If you are not using the CQG data for any other purpose, then you should stop paying for that data from CQG.
[2025-02-05 07:45:44]
Ok no problem, is that the same for CME data?
I have to keep CGQ as it allows ICE outright and calendar spreads, and (some) SGX data.
[2025-02-05 15:51:45]
We do not have support for the CME Group data from CQG or Rithmic. Since you are using CQG, you would need to get your CME Group data from us as well. Follow the instructions at the following link to do this:
You can get ICE and SGX data from CQG into Sierra Chart. You just need to enter the appropriate symbol in the "Selected Symbol" field on the Find Symbol window.
[2025-02-05 20:09:25]
Thank you John, that's crystal clear. Appreciate your replies.
All the best.
