Date/Time: Wed, 19 Aug 2026 23:30:28 +0000
Problem to open earlier data
View Count: 1229
| [2014-09-14 19:46:37] |
| User511456 - Posts: 3 |
I have SC from Infinity like ATchart. I can not open earlier contract months than only current. If I want to join NQU4 + NQZ4 in join intraday data files then can not modify these data. I cannot join and modify NQU4, and NQZ4. Is ATchart limited on features from the full version number 3 - from your site? Or something needs to be set in ATChart I can open and edit older data? Thank you for help. |
| [2014-09-14 20:03:36] |
What version of Sierra Chart are you running? You should have no trouble at all opening previous futures contracts. Refer to help topic 42.2 here: http://www.sierrachart.com/index.php?page=doc/helpdetails42.html You also do not need to join files. You only need to use the Continuous Users Contract feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-14 20:29:01] |
I have ver.1187. I have problem to open all older contract month to join. |
| [2014-09-14 20:53:42] |
When I join data, then SC write: JoinData: Failed to open the temporary output file. Failed to open file C:\SierraChart\SierraChartTransActMA\Data\JoinData.NQU4-1.scid.temp to replace it. Error: | 2014-09-14 14:01:06 * JoinData: Join complete. No records were read. Nothing was written to NQU4-1.scid. | 2014-09-14 14:01:06 Where is problem? |
| [2014-09-15 10:05:17] |
Are you having a problem only when you try to join Intraday data files or opening a chart for an expired futures contract? The problem with joining Intraday data files has been resolved. Update Sierra Chart by selecting Help >> Download Prerelease. And also we strongly recommend using the Continuous Futures Contract feature. The Intraday data joining method is out of date . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
