Date/Time: Thu, 20 Aug 2026 00:05:03 +0000
Spreadsheet results switching between 2 symbols/chartbooks..
View Count: 1268
[2014-09-10 14:53:22]
The Stealthy Trader - Posts: 190
So, sometimes my spreadsheet results flicker between chartbooks.
As an example:
In Chartbook A, Sheet #1 I have Symbol PRAN($2.37)
In Chartbook B, Sheet #1 I have Symbol ACCO($7.85)
I'll be observing normal results in A/#1 and then the results will show B/#1 and then back to A/#1..w/o me doing a thing.
Is there a spreadsheet setting that prevents this kind of switching?
Thanks,
J.
[2014-09-10 15:12:32]
Sawtooth - Posts: 4346
Each chartbook should use a separately-named spreadsheet; IOW don't concurrently use the same-named spreadsheet in two concurrently open chartbooks.
[2014-09-10 15:44:48]
Appreciate the heads up as I didn't know that..
Making changes now..
Btw, what does IOW mean?
[2014-09-10 15:45:37]
IOW = In Other Words
[2014-09-10 15:46:04]
[2014-09-10 16:21:03]
Yes. Definitely do use a separate Spreadsheet for each Chartbook. Or use different Sheets by changing the Chart Data Output Sheet Number input with the Spreadsheet study.
[2014-09-11 14:15:38]
Hi, so I've created 3 differently named spreadsheets.
However, when I open the spreadsheet that matches a particular chartbook, it also opens in the other 3 chartbooks causing me to have multiple different spreadsheets open in each chartbook.
I thought it was supposed to be like this:
Chartbook A/Spreadsheet A
Chartbook B/Spreadsheet B
But now I have..
Chartbook B/Spreadsheet A&B..
If I close spreadsheet A it also closes in Chartbook A..which I don't want.
Please advise...
J.
Please advise
Date Time Of Last Edit: 2014-09-11 14:16:33
[2014-09-11 17:45:40]
Unless a Spreadsheet is opened by a Spreadsheet Study on a chart in a Chartbook, it will be visible across Chartbooks.
Date Time Of Last Edit: 2014-09-11 17:45:51
