Date/Time: Wed, 19 Aug 2026 23:27:46 +0000
Historical data
View Count: 1306
| [2014-09-10 06:25:36] |
| User78347 - Posts: 17 |
I'm trading the 6E future contract. On this contract i'm able to get history data until 16.9.2013 (see picture attached). I would like to get historical data from 2012 how can i do it? I wasn't able to change the date on the chart setting (see picture attached) |
Attachment Deleted. |
| [2014-09-10 09:55:14] |
Based upon what we see, re-download the data following these instructions: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading The settings are correct. We do not see any problems with those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-11 06:29:29] |
Thank you. I re-download the data following the instructions and i still have problem with the data. The history data is until 16.9.2013 (see new picture attached). There is a gap between 16.9.2013 untill 2006!! and i can't see this data. Once again I wasn't able to change the date on the chart setting (see new picture attached) |
| [2014-09-11 06:33:39] |
We need to test this. Do not worry about the Date Range, that only applies to the current contract. Not the historical contracts loaded in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-11 18:48:05] |
We think that you did not follow through the procedure to re-download the data for all of the futures contract symbols in the chart. The chart looks proper for us: http://www.sierrachart.com/image.php?l=141046121448.png The easiest thing to do is to select File >> Open Historical Chart. Delete all of the E6*.dly files. Press Cancel. Go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-11 18:48:52
