Date/Time: Wed, 13 May 2026 13:23:14 +0000
Individual standard deviation tool
View Count: 1007
[2024-10-30 17:18:19]
User258227 - Posts: 8
I have the following problem.
I need an indicator or drawing tool that shows me the following data for the current day as lines (with price and individual color/with) in the chart (from the beginning to the end of the day):
Standard line = price (which I set) or close from the previous day
Standard deviation up and down (x in per cent or points, which I determine) from the standard price. 1 2 and 3 (individually adjustable, e.g. 0.5, 1, 1.5)
These standard deviations should be drawn separately for each day. (Zero line and different deviations)
I hope you understand what I mean.
Thank you and best regards,
Stefan
[2024-10-30 18:31:16]
John - SC Support - Posts: 46104
The hardest part of this is defining the line. If you want to do it from the close of the previous day, then you would use the "Horizontal Line at Time" study and set the time of the line to 1 second before the start of the next day's session. For instance, for the CME Group, many products stop trading at 16:00:00 and then the Evening Session starts at 17:00:00, therefore to get the close of the previous day, you would set the time to be 15:59:59 and the Input Data as "Last".
Then use the "Bands/Envelope" study to get bands drawn at specific offsets.
If you want Standard Deviations, then you would need to have data over a period of time, therefore you could use the "Standard Error Bands" study.
Refer to the following:
Bands/Envelope
[2024-10-30 20:25:40]
I have found an indicator that does exactly what I want, but my results in cl differ from the author's results in es.
With sigma 1 and 1.53 as the volatility in ticks, 67.97 should come out for up (see screenshot excel). However, 67.86 comes out.
I have attached my screenshots and those of the author, along with the indicator.
Maybe you can explain to me where the difference comes from?
That would be very nice and helpful.
Thank you in advance
next 3 files in seperate upload
Private File
imageInput Original ES.png / V - Attached On 2024-10-30 20:24:17 UTC - Size: 28.69 KB - 159 views
imageInputs of ME CL.png / V - Attached On 2024-10-30 20:24:21 UTC - Size: 70.68 KB - 168 views
[2024-10-30 20:26:16]
next 3 files
imageScreenshot of ME CL.png / V - Attached On 2024-10-30 20:26:00 UTC - Size: 91.66 KB - 150 views
imageScreenshot original ES.png / V - Attached On 2024-10-30 20:26:03 UTC - Size: 46.04 KB - 154 views
imageScreenshot_1.png / V - Attached On 2024-10-30 20:26:07 UTC - Size: 15.7 KB - 160 views
[2024-10-30 20:30:05]
Sorry,
the result should be 68.74 for the first standard deviation, not 67.97.
[2024-10-30 20:54:03]
This is the link i have the indicator
https://www.reddit.com/r/thewallstreet/comments/gzbpeh/sierra_chart_daily_standard_deviation_study/?utm_source=share&utm_medium=mweb3x&utm_name=mweb3xcss&utm_term=1&utm_content=share_button
[2024-10-30 21:51:55]
We can not look into third party studies. You would need to ask the developer of the study why you are not getting what you expect.
