Date/Time: Tue, 16 Jun 2026 02:39:36 +0000
exchange traded spread for Nat Gas
View Count: 655
[2024-10-28 20:57:49]
larryson - Posts: 1
Hi there,
I would like to trade exchange traded spreads of Natural Gas, looking at calendar spreads of Dec 2024 - Jan 2025. I used to be able to trade this fine under ironbeam, but can't seem to do so in SierraChart.
https://www.barchart.com/futures/quotes/_S_SP_NGZ4_NGF5/interactive-chart
Can you please advice on this matter please?
[2024-10-28 22:52:15]
John - SC Support - Posts: 46708
The account you have posted from is expired, therefore you can not do anything with the account.
If you have another active account, then we need for you to post from that account.
[2024-10-29 06:53:11]
Goldsea - Posts: 13
Posting from this account.
[2024-10-29 07:09:52]
Goldsea - Posts: 13
Hi there,
[2024-10-29 15:29:50]
Refer to the following for how to get the Spread data:
Denali Exchange Data Feed: Denali Exchange Traded Spread Data with Trading Service
[2024-10-29 21:04:18]
Goldsea - Posts: 13
Thank you, when I open find symbols this is not what I see.
Is this because of my data fee? I currently under the Denali - Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts - @ $5.5 per month.
Appreciate your help on this matter.
imagesierrachart.PNG / V - Attached On 2024-10-29 21:03:08 UTC - Size: 138.73 KB - 160 views
[2024-10-29 21:18:45]
Goldsea - Posts: 13
See attached image showing what I see when I enter NGZ24-NGH25_FUT_SPREAD_CME
imagesierrachart1.PNG / V - Attached On 2024-10-29 21:17:50 UTC - Size: 113.42 KB - 178 views
[2024-10-29 23:37:17]
What is "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" set to?
[2024-10-30 10:45:13]
Goldsea - Posts: 13
It is set to Teton CME Order Routing, under ironbeam.
[2024-10-30 10:45:47]
Goldsea - Posts: 13
See attached
imagesierrachart2.PNG / V - Attached On 2024-10-30 10:45:38 UTC - Size: 127.2 KB - 151 views
[2024-10-30 15:54:16]
The correct symbol for this is the following:
NGZ24-NGH25.FUT_SPREAD.CME
You have an Underscore instead of a Period before the CME at the end.
If you found the symbol through "File >> Find Symbol" then it should have been correct, and we are curious as why it would not be.
[2024-10-30 20:25:11]
Goldsea - Posts: 13
Many thanks, this works now.
[2024-11-01 10:33:28]
Goldsea - Posts: 13
Can you advice on how to remove NGF25 and NGZ24 from my Chart Stats, I have removed those charts from my chartbook, but it is still there.
As right now, it is showing double PnL
Date Time Of Last Edit: 2024-11-01 10:47:29
imagesierrachart3.PNG / V - Attached On 2024-11-01 10:31:07 UTC - Size: 221.18 KB - 169 views
[2024-11-01 15:15:30]
Sierra_Chart Engineering - Posts: 24034
Go to each of those charts, #3 and #4, and set this Chart Setting to No:
Chart Settings: Include Chart Trade List in Trade Statistics for Chart Window (Chart >> Chart Settings >> Trading menu)
Also those charts must actually exist. They must. Maybe in another Chartbook that is open.
