Date/Time: Wed, 17 Dec 2025 06:43:56 +0000
Market profile horizontal bar length reduction
View Count: 302
| [2024-10-28 15:24:57] |
| User183193 - Posts: 11 |
Hello, when I increase the number of ticks in the market profile bars (50, 60 ticks etc.), they take up too much space horizontally and do not fit on my screen. How can I shorten the length of the bars horizontally when I increase the ticks? Thanks (screenshot is attached) |
| [2024-10-28 15:55:35] |
| John - SC Support - Posts: 43500 |
TPO Profiles do not have a control over how the bars are drawn, unlike the Volume Profiles. This is because a TPO chart does not exist on its own, it specifically covers the time period for which you have specified the profile. Therefore the only way to change the size of the bars is to change the bar spacing. Refer to the following: Working With Charts: Changing Bar Spacing We are not sure if that profile you are showing is a TPO or Volume profile. If it is a volume profile, then refer to the following: Time Price Opportunity (TPO) Profile Charts: Percent Width For Volume Profile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
