Date/Time: Sat, 15 Aug 2026 00:39:10 +0000
[Programming Help] - Ability to change the selected Tool (Pointer to Hand) within custom ACSIL study function
View Count: 867
[2024-10-13 16:22:41]
AlpineFutures - Posts: 1
I'm writing a custom ACSIL study, and I am trying to get the study function to change the selected tool at a certain point.
For example, I would like the study to change the Tool from Hand to Pointer, and then later, switch back to Hand.
Is this possible? I've only been able to find documentation regarding the Tools >> Tool Settings >> General >> After Single Use Tool Change To (List), however this doesn't work as I am not actually using a drawing tool. Instead, the study itself is using sc.UseTool to make some drawings. I've tried setting those drawings as UserDrawings (Tool.AddAsUserDrawnDrawing = 1). This does set them as UserDrawings (I can interact with them once drawn), but it does not return the Tool to the one selected in the (List).
Thanks for any help.
[2024-12-09 20:37:22]
Sierra_Chart Engineering - Posts: 24564
There is not a way to change the currently selected Chart Drawing Tool from ACSIL but we can look at adding that capability.
[2026-05-24 18:55:26]
ForgivingComputers.com - Posts: 1235
Any update on this? Something like
sc.SetChartDrawingTool(POINTER_HAND);
[2026-06-25 07:17:52]
We will look into this.
