Date/Time: Thu, 10 Sep 2026 16:44:14 +0000
MATIF MILLING WHEAT
View Count: 1101
[2024-09-12 14:10:11]
User624595 - Posts: 263
Please add Matif Milling Wheat symbol.
https://live.euronext.com/en/product/commodities-futures/EBM-DPAR/instrument?Class_symbol=EBM&Class_exchange=DPAR&fOrO=F&md=12-2024
https://www.barchart.com/futures/quotes/ML*0
Symbol EBM at IB:
https://misc.interactivebrokers.com/cstools/contract_info/v3.10/index.php
[2024-09-13 16:53:09]
Sierra_Chart Engineering - Posts: 24822
We will set this up.
[2024-09-13 17:16:27]
This is added.
[2025-01-14 04:01:32]
Please add Matif Rapeseed also:
https://live.euronext.com/en/product/commodities-futures/ECO-DPAR/contract-specification
https://www.barchart.com/futures/quotes/XRK25/overview
[2025-01-20 22:40:20]
As a matter of policy these particular symbols will not be added.
They are not part of data feeds that Sierra Chart is providing. You can manually specify the symbols.
Date Time Of Last Edit: 2025-01-20 22:40:27
[2025-01-22 03:22:21]
Could you link documentation on how to do this properly manually?
[2025-01-22 16:58:09]
John - SC Support - Posts: 47833
You type in the particular symbol, as it is needed for the service you are connected to, in the "Selected Symbol" field on the "File >> Find Symbol" window. Then open the appropriate chart type from there. Refer to the following:
File Menu: Find Symbol (File)
[2025-01-22 17:16:32]
What about the tick settings, price increments, contract size, currency values?
[2025-01-22 19:34:11]
Tick Size, and Price Increment should come from the data feed. You may need to check the Currency Value per tick to make sure it is also coming in correctly and adjust it in your Chart Settings if it is not right.
[2025-01-30 07:28:51]
How can the correct symbol be determined when trying to add it for the first time? We are not able to find new symbols for global futures that are not listed by using Find Symbols.
ie, currently need to add Iron Ore on SGX, do not see it listed, can not find it in search in Find Symbols. How can it be added? Have found past posts indicating it was added, but cannot find it. SGX iron ore data
[2025-01-30 15:15:29]
You type in the symbol based on the symbol requirements from your trading service. In this case, you would need to ask Interactive Brokers for the symbol they use for that product. Then you type that into the "Selected Symbol" field on the "Find Symbol" window and then select the appropriate option for what kind of chart you want to open.
[2025-01-30 19:00:21]
We will try to get this set up as soon as we can in the symbol settings.
[2025-01-30 21:22:31]
Actually we decided not to add the symbols.
We do not have sufficient information. A link directly to the very specific information from Interactive Brokers on the specific contract to be added. Otherwise we will not get involved in this. You need to ask Interactive Brokers for all of the details, and assemble the symbol according to the specifications here:
Interactive Brokers Symbols
If you can provide us data like this, we can add it to the Interactive Brokers symbols file:
<settings>
<symbol>EBM-######-MATIF-EUR-50</symbol>
<use-pattern-matching-characters>true</use-pattern-matching-characters>
<contract-months>HKUZ</contract-months>
<description>Milling Wheat Futures - MATIF</description>
<category>Futures</category>
<security-type>futures</security-type>
    <supports-market-depth>true</supports-market-depth>
<value-format-code>2</value-format-code>
<tick-size>.25</tick-size>
<currency-value-per-tick>12.50</currency-value-per-tick>
<default-order-quantity>1</default-order-quantity>
<rollover-method></rollover-method>
<rollover-input-1></rollover-input-1>
<rollover-input-2></rollover-input-2>
</settings>
So this is something that we can do.
Date Time Of Last Edit: 2025-01-30 21:24:11
[2025-02-05 07:55:35]
Are the specific links in the first post enough to add new symbols? Appears Milling Wheat was added and is now working.
Looking to add European Corn on Matif (eventually the remaining European grains)
https://live.euronext.com/en/products/commodities
And Iron Ore on SGX. Not sure how it was added in the past but no longer shows.
https://www.sgx.com/derivatives/products/iron-ore
Date Time Of Last Edit: 2025-02-05 07:56:26
[2025-02-10 08:11:34]
Can you please get us the links to the Contract specifications from Interactive Brokers website. This is what we need.
