Date/Time: Wed, 09 Sep 2026 09:59:34 +0000
Changes to Chart Settings > Chart Data > Dates to Exclude ignored
View Count: 855
| [2024-09-09 00:24:07] |
| Mark Lewis - Posts: 27 |
I'm using sc.AddDateToExclude() in my custom study. It successfully adds a date to Dates to Exclude but it is ignored. I have tried using sc.FlagToReloadChartData = 1 and opened Chart Settings > Chart Data > Dates to Exclude directly to apply settings. The only way the date is excluded from the data is if I make a change directly in settings. Perhaps the setting is cached causing the additions via ACSIL to be ignored? Here is the code that successfully adds the date to the Chart Settings > Chart Data > Dates to Exclude. The code works, but the information is not used. if (sc.MenuEventID != 0) { if (sc.MenuEventID == r_ExcludeDateMenuID) { SCDateTime SelectedTPODateTime = sc.BaseDateTimeIn[sc.ActiveToolIndex]; sc.AddDateToExclude(ChartNumber, SelectedTPODateTime); sc.FlagToReloadChartData = 1; } if (sc.MenuEventID == r_ClearExcludedDatesMenuID) { sc.DatesToExcludeClear(ChartNumber); sc.FlagToReloadChartData = 1; } } Thank you for looking into this! Date Time Of Last Edit: 2024-09-09 00:26:46
| [2024-09-09 02:16:30] |
| Sierra_Chart Engineering - Posts: 24815 |
We will solve this. Update: we need more time to look into this because it does not look to us there is a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-09 13:39:56
| [2024-09-09 19:00:25] |
To clarify, I'm trying to accomplish this on a chart accompanied by the built-in TPO Profile Chart study. I have isolated the code to the following study and can reproduce the problem consistently on my end. Thanks again for looking into this! #include "sierrachart.h" SCDLLName("TPO Test") /*==========================================================================*/ SCSFExport scsf_TPOTest(SCStudyInterfaceRef sc) { // Set configuration variables if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "TPO Test"; sc.GraphRegion = 0; sc.AutoLoop = 0; return; } int& r_ExcludeDateMenuID = sc.GetPersistentInt(1); int& r_ClearExcludedDatesMenuID = sc.GetPersistentInt(2); if (sc.IsFullRecalculation != 0) { if (r_ExcludeDateMenuID <= 0) { r_ExcludeDateMenuID = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Add date to exclude list"); r_ClearExcludedDatesMenuID = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Clear excluded dates"); } } if (sc.MenuEventID != 0) { if (sc.MenuEventID == r_ExcludeDateMenuID) { SCDateTime SelectedTPODateTime = sc.BaseDateTimeIn[sc.ActiveToolIndex]; sc.AddDateToExclude(sc.ChartNumber, SelectedTPODateTime); sc.FlagToReloadChartData = 1; } if (sc.MenuEventID == r_ClearExcludedDatesMenuID) { sc.DatesToExcludeClear(sc.ChartNumber); sc.FlagToReloadChartData = 1; } } } |
| [2024-10-11 18:30:38] |
The problem is this date-time has a small time component: SCDateTime SelectedTPODateTime = sc.BaseDateTimeIn[sc.ActiveToolIndex];
That needs to be removed like this: SCDateTime SelectedTPODateTime = sc.BaseDateTimeIn[sc.ActiveToolIndex].GetDateAsSCDateTime();
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-11 18:30:59
