Date/Time: Fri, 13 Mar 2026 20:37:49 +0000
Stoch RSI
View Count: 1488
| [2014-08-30 11:35:06] |
| ripsdips - Posts: 143 |
Im looking for a StochRSI that I can input more values. Is the one on the studies list the only one available from SC?
| [2014-08-30 12:07:56] |
| User64662 - Posts: 15 |
Did you try adding another StochRSI into same region and change values and colors. Also look in Add custom studies. I'm not sure if that's what your trying to do. I'm new learning in Sierra while reading in support. |
| [2014-08-30 14:12:12] |
thanks
| [2014-08-31 22:37:52] |
Sierra Chart only has 1 Stochastic RSI. However, the source code is provided and can be changed. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
