Date/Time: Wed, 11 Feb 2026 15:13:46 +0000
[Locked] - CFE and NASDAQ TotalView Changes and Required Update July 13, 2024
View Count: 4486
[2024-07-08 21:27:42]
Sierra_Chart Engineering - Posts: 22801
There are some changes with NASDAQ TotalView data:
1. It will be required to be running version 2654 or higher to continue to access NASDAQ TotalView data after July 13, 2024. Instructions to update:
We are moving NASDAQ TotalView to a separate process to ensure the very lowest latency.
This is also true for CFE data as well. You need to update Sierra Chart to the current version to access CFE data.
2. All historical data for -NQTV symbols will be removed from before July 11, 2022. For longer-term historical data, use the US equities consolidated tape data feed symbols:
US Stock/Equities Consolidated Tape Data Feed
The reason for this is data before this date is not actual NASDAQ TotalView data. It is consolidated tape data. And does not match to TotalView data and requires special maintenance which has not been done, except for the actual consolidated tape symbols.
Date Time Of Last Edit: 2024-08-27 16:21:43
[2024-08-27 16:22:17]
To access CFE data or CBOE Futures data you need to be running an up-to-date version of Sierra Chart. Instructions to update:
