Date/Time: Tue, 12 May 2026 00:08:48 +0000
[Programming Help] - Numbers Bars - Calculated Values
View Count: 7230
| [2024-05-03 17:51:19] |
| User993067 - Posts: 193 |
Is there a setting in the NBCV or NBCV2 tool that can calculate: 1. Cumulative Delta over last X bars? the only options I see are for the present bar or the cumulative bars of the entire day. If I scalp intraday the daily CD is too slow to respond to micro single bar shifts in the delta...being able to add a custom delta setting helps tremendously to find the current accum/dist over the last few minutes or bars etc. 2. POC delta? 3. Cumulative POC delta last X bars? 4. Diagonal Imbalanced Delta, per bar and cumulative over X bars Can these be added to NBCV or NBCV2? Or even better can I access these calcs in spreadsheet and have spreadsheet values display in NBCV grid? This way the NBCV grid can be fully user customized with background color options etc of any calculation the user wishes. |
| [2024-05-03 19:04:32] |
| John - SC Support - Posts: 46072 |
To start with, these items are not available in the Numbers Bars Calculated Values studies. Also, there is not a way to add information from another study to the Numbers Bars Calculated Values studies. You can create a custom study that can use the same tabular format as the Numbers Bars Calculated Values. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type The general answer for how to calculate these items over X number of bars is to use a different chart with the bar period set to the time for which you want the information, then pull the information for those bars and display it in the chart where you want to view it. You can either use the "Study/Price Overlay" or the "Text Display for Study from Chart". 1. You can get the Delta per bar from the Numbers Bars Calculated Values study. 2. You can get the delta for the POC by using the "Spreadsheet Formula" and the Alert functions for finding the Bid and Ask volumes at price as defined here: Study/Chart Alerts And Scanning: Special Functions You can get the POC price from the "Volume Point of Control for Bars" study. Refer to the following: Volume Point of Control for Bars For example, you would enter the following formula in the Spreadsheet formula: =AVAP(ID1.SG1, 0) - BVAP(ID1.SG1, 0) Where ID1 is the ID of the "Volume Point of Control for Bars" and SG1 is the Subgraph of the "Volume Point of Control for Bars". 3. You would have to sum up the data. 4. You would have to do the calculations for this and get the data from the Numbers Bars Calculated Values study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-05-03 21:31:51] |
Thank you for the detailed response, I am trying to officially migrate to SC 100%. However, I cannot because there is data I can access in MC that I cant in SC. I NEED not want the delta over last X bars in order to trade, its not optional. I am a trader not a programmer so your custom study solution is beyond my capability. after having been at this for hours I see potential workaround, but cant get it to work at present configuration. The study: summation of study subgraph does exactly what I need...it allows for referencing any study including those in NBCV or NBCV2 with adjustable periodicity, but I need the data displayed in the NBCV grid, with background color changes, so i can view immediate shifts and context, not plotted as a line or graph. the NBCV NBCV2 allows for referencing data from another chart, but it only seems to be able to reference/plot other NBCV data, because those are the only subgraph options available to be displayed. If there were additional subgraph(s) option added to NBCV or NBCV2 that allowed for referencing other data external of the NBCV or NBCV2 from the chart this could be done exactly as I need. These additional subgraph(s) will allow all users to view virtually any data they desire into the NBCV grid, and allow SC to stop fielding requests for adding specific additional calcs to the grid. which is currently at 54, I only need 3. |
| [2024-05-05 15:07:27] |
Sorry, but there is not a built-in way to add items to the tabular setup that is used by the Numbers Bars Calculated Values. The only way to do this is to create a custom study. If you are not able to do the programming, you can hire it out. Refer to the following: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-03 09:06:00] |
| Lowry BigEarth - Posts: 50 |
Hi, Also, there is not a way to add information from another study to the Numbers Bars Calculated Values studies.
How to get values out of numbers bars chart (custom study ID1) into ID2 custom study (trading strategy)? Message log shows that only one study is on = ID2. Chart shows ID1 and ID2. Have set manually to connect the 2 studies. Issue: the trade entry conditions based on settings does not match the values on the chart. Thnx, Date Time Of Last Edit: 2025-10-03 09:07:16
| [2025-10-03 15:47:11] |
What trading system are you using? Is this a custom study or one of the built-in studies? If it is one of the built-in studies, which one are you using?
| [2025-10-03 16:05:03] |
frederik at simple system trading has an indicator in his free bundle package that may do what you are looking for...allows you to assemble subgraph values in a grid beneath below price...SG Values Grid https://www.simplesystemtrading.com/ |
Attachment Deleted. |
| [2025-10-03 16:05:52] |
Both custom studies.
| [2025-10-03 16:42:59] |
If you want to get the data for another study within a Custom Study, then refer to the following: ACSIL Interface Members - Functions: sc.GetStudyArrayUsingID() There are also other functions to get study arrays from different charts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-03 16:43:43] |
User993067: We put out a study to do this awhile ago. Refer to the following: Numeric Information Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-04 10:32:25] |
Thank you... C attached... if you could guide further? ...so the other study ID2 can calculate whatever the settings are requiring to calculate. Thank you. have to use thisone, right > ACSIL Interface Members - Functions: sc.GetStudyArrayUsingID() ? Date Time Of Last Edit: 2025-10-05 07:31:46
| [2025-10-05 10:31:32] |
| User431178 - Posts: 867 |
You can't access that data via subgraphs, you need to use the volume at price data. ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars |
| [2025-11-14 07:39:02] |
| User265694 - Posts: 7 |
Hi, How to get values - price bid ask delta every tick level - from n number of previous bars? Thnx.
| [2025-11-14 18:28:05] |
| Sierra_Chart Engineering - Posts: 23735 |
You need to set the Intraday Bar Period Type to Number of Trades Per Bar: Chart Settings: Bar Period Type (List) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings) And use a value of 1. Reduce the Days to Load in the chart: Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load) And use this study: Ask/Bid Volume Difference Bars Create your own custom studied to do these: 1. Cumulative Delta over last X bars?
the only options I see are for the present bar or the cumulative bars of the entire day. If I scalp intraday the daily CD is too slow to respond to micro single bar shifts in the delta...being able to add a custom delta setting helps tremendously to find the current accum/dist over the last few minutes or bars etc. 2. POC delta? 3. Cumulative POC delta last X bars? 4. Diagonal Imbalanced Delta, per bar and cumulative over X bars Can these be added to NBCV or NBCV2? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-14 19:10:15] |
Thank you, I have a footprint / numbers bar chart (bid-ask-delta visible) of 200 delta. And I want all values of every tick level from previous bar (200 delta) into the study. Seems study cannot get / fetch the values from previous bar? > keeps telling me: Code 8998 full recalculation cannot enter order until new bar begins.
| [2025-11-17 22:00:41] |
We do not understand this: Seems study cannot get / fetch the values from previous bar? >
Every bar within a Numbers Bars chart, is for that chart bar itself. Never the previous one. We do not know the relevancy of this to the question: keeps telling me: Code 8998 full recalculation cannot enter order until new bar begins.
That error simply means, that when the study was being fully recalculated, order entry is not allowed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-17 22:02:37
