Date/Time: Fri, 19 Apr 2024 04:22:23 +0000
ChartDOM Scaling Issue
View Count: 1810
[2013-05-03 21:47:36] |
What happens when you compress the scale using Interactive Scale Range: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling For now set the Scale Increment in the Chart >> Chart Settings >> Scale settings to the Tick Size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
