Date/Time: Fri, 13 Mar 2026 19:44:34 +0000
Double VPOCS on DYU14 (M)
View Count: 1097
[2014-07-09 19:03:37]
User86139 - Posts: 10
SC Data Exchange. A second VPOC has appeared on the VBP study.
(see attachment).
This obviously renders the profile as unusable.
attachmentAshampoo_Snap_2014.07.09_20h00m21s_001_.bmp - Attached On 2014-07-09 19:01:31 UTC - Size: 5.09 MB - 530 views
[2014-07-10 04:57:25]
We do see the second volume bar you are pointing out, but it is not highlighted as a volume point of control.
Therefore, it has a slightly different volume than the point of control volume bar.
While it is unlikely, there is the possibility that there could be two volume bars with the same volume. And if that is the maximum volume, they both would be the point of control.
