Date/Time: Fri, 13 Mar 2026 19:36:50 +0000
"Stuck" order
View Count: 1231
[2014-07-09 15:59:58]
T44 - Posts: 363
There was an error with the order cancellation: Unable to cancel order without a Service Order ID. Internal Order ID: 12815. Internal order ID: 12815 | 2014-07-09 11:57:55
CTS FIX: Received LastRptRequested in execution report for account: 13769. Inserting missing order fills. | 2014-07-09 11:58:04
There is an order appearing which was sent while the platform wasn't connected properly. Every time I log in, this order appears, however I cannot cancel it. I have checked logging into the CTS T4 platform directly and the order does not exist.
How can I purge this rogue order from Sierra / make sure Sierra is not trying to re-send this order?
[2014-07-09 16:01:27]
T44 - Posts: 363
Update: closing and re-opening the platform twice more appears to have solved the issue.
Date Time Of Last Edit: 2014-07-09 16:01:42
[2014-07-09 16:18:12]
Next time this happens, what you need to do is select Trade >>Refresh Trade Data from Service. The order will be cleared in about 40 seconds. Not immediately though.
