Date/Time: Fri, 13 Mar 2026 20:18:33 +0000
Problems Trying to Build an Advanced Custom Study from Source Code
View Count: 1605
| [2014-07-08 18:23:41] |
| kleros - Posts: 21 |
I have a .cpp file that i am trying to convert into an advanced study. I am getting the following error when I try to install the Compiler. Please help. Chris ====================== C:\SierraChart\CPPCompiler\bin>mingw-get install libz-dll mingw-get: *** WARNING *** C:\SierraChart\CPPCompiler\var/lib/mingw-get/data/pro file.xml: user configuration file missing mingw-get: *** INFO *** C:\SierraChart\CPPCompiler\var/lib/mingw-get/data/defaul ts.xml: trying system default configuration install: libz-1.2.8-1-mingw32-dll-1.tar mingw-get: *** ERROR *** package libz-1.2.8-1-mingw32-dll-1.tar is already insta lled C:\SierraChart\CPPCompiler\bin>pause Press any key to continue . . . |
| [2014-07-08 21:24:55] |
These errors might be OK and not cause a problem. Try building a custom studies DLL.
| [2014-07-09 15:06:16] |
I get the following error when I try t build a custome studies DLL. -- Starting build of Custom Studies Source files: HilbertSineWaveSR.cpp. -- 08:03:30 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\HilbertSineWaveSR.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\HilbertSineWaveSR.dll" C:\SierraChart\ACS_Source\HilbertSineWaveSR.cpp:43:10: error: expected constructor, destructor, or type conversion before '(' token SCDLLInit("HilbertSineWaveSR") ^ -- End of Build -- 08:03:39 |
| [2014-07-09 16:16:21] |
Change this: SCDLLInit("HilbertSineWaveSR") to: SCDLLName("HilbertSineWaveSR") Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-09 16:16:44
| [2014-07-09 17:02:15] |
It works now. Thanks.
