Date/Time: Sat, 05 Sep 2026 17:59:40 +0000
spreadsheet question
View Count: 1268
| [2014-07-07 22:08:43] |
| User021827 - Posts: 174 |
If I have a spreadsheet for automation on 4 different symbols in 4 different chartbooks, and I make a change to one of the spreadsheets, will the change affect the other symbols if they are all using defaultspreadsheet ? thanks shane |
| [2014-07-07 22:31:48] |
The answer depends upon what you are changing and the Formula Source Sheet Number setting: Spreadsheet Study Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-07 22:31:56
| [2014-07-07 22:49:34] |
thanks
