Date/Time: Fri, 13 Mar 2026 20:17:55 +0000
OEC non connect - will advise broker also.
View Count: 1165
| [2014-07-07 12:29:35] |
| User48838 - Posts: 131 |
OEC FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-07-07 08:27:58 Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-07-07 08:27:58 The network socket is connected. | 2014-07-07 08:27:58 OEC FIX Trading: Sending the Logon message. | 2014-07-07 08:27:58 Socket closed. No error. | 2014-07-07 08:27:58 Socket has been shutdown and closed. | 2014-07-07 08:27:58 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-07-07 08:27:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-07 08:27:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-07 08:27:58 Disconnected from Open E Cry. | 2014-07-07 08:27:58 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-07 08:27:58 File >> Disconnect selected. | 2014-07-07 08:27:59 Disconnected from Open E Cry. | 2014-07-07 08:27:59 |
| [2014-07-07 14:28:52] |
all set on brokers end, p[lease disregard
| [2014-07-07 16:14:04] |
Here is the OEC specific documentation for a problem like this: http://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
