Date/Time: Fri, 13 Mar 2026 19:50:11 +0000
OpenChartOrGetChartReference
View Count: 1569
| [2014-07-05 06:35:54] |
| tickHunter - Posts: 14 |
I am trying to open a chart using sc.OpenChartOrGetChartReference(). Am I correct in thinking that I can use this function in an ACSIL study to open a chart set to some particular start time? Following the example provided in studies.cpp, here is a portion of the relevant code: int& ChartNumber = sc.PersistVars->i1; s_ACSOpenChartParameters OpenChartParameters; OpenChartParameters.PriorChartNumber = ChartNumber; OpenChartParameters.ChartDataType = INTRADAY_DATA; //This can also be set to: DAILY_DATA OpenChartParameters.Symbol = sc.GetRealTimeSymbol();//When want to use the symbol of the chart the study function is on, use sc.GetRealTimeSymbol() OpenChartParameters.IntradayBarPeriodType = IBPT_DAYS_MINS_SECS; OpenChartParameters.IntradayBarPeriodLength = 30*SECONDS_PER_MINUTE; // 30 minutes OpenChartParameters.SessionStartTime.SetTimeHMS(9,30,53); //some arbitrary start time OpenChartParameters.SessionEndTime.SetTimeHMS(15,14,59); The new chart which is opened using this function is always set to a start time of 00:00:00, regardless of the value set during initialization of the object. Thanks! Date Time Of Last Edit: 2014-07-05 22:35:11
| [2014-07-07 16:22:57] |
We will be testing this today.
| [2014-07-08 02:10:13] |
This will be solved in the next release.
