Date/Time: Wed, 17 Apr 2024 18:42:53 +0000
[User Discussion] - View and trade multiple symbols at omce
View Count: 321
[2023-03-10 11:22:27] |
User277159 - Posts: 13 |
Hi, I was wondering how I best trade two three or more symbols at the same time, without having to toggle between chart books and losing visibility on one when checking another, Ideally I’d like to watch crude and the pound at the same time for example, is it possible? If so how? I was wondering if it would be better to download another version of sierra and use it as a second display? Look forward to hearing from you |
[2023-03-10 17:58:34] |
bradh - Posts: 853 |
You can have multiple charts open in one chartbook. Each chart can have its own Chart Settings. If you like, the charts can be detached from the main window and placed anywhere, including on other displays. You can also drag the main window's corners/edges to cover multiple screens. You can run another instance on another display, which allows two chartbooks to be visible at the same time, but I wouldn't recommend doing one instance per symbol nor one chartbook per symbol if you are trading 3 or more. |
