Date/Time: Thu, 28 Mar 2024 22:22:59 +0000
The remote build did not succeed
View Count: 483
[2023-03-09 23:01:57] |
axis4th - Posts: 5 |
what could be the problem? Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: No result text was given. -- End of Build -- 16:52:48 https://i.imgur.com/QzbnvYE.png Date Time Of Last Edit: 2023-03-09 23:02:40
[2023-03-10 00:10:56] |
SavantTrader - Posts: 108 |
I am getting the same thing, for a studies DLL bundle that compiled successfully just days ago. I think some back-end machine that takes care of the remote builds needs to perhaps be reset. SUPPORT - CAN YOU PLEASE CHECK. Thank you! |
[2023-03-10 01:41:27] |
lol my last dll was created less than 10 minutes before the this error |
[2023-03-10 01:55:36] |
Tony - Posts: 454 |
I suggested that you guys build locally, which operating systems are you guys using? For Windows: Download free "Visual Studio Community" and install, (select all C++ options in the installer window). In Sierra Chart, go to: Analysis --> Build Custom Studies DLL and in the "Build Advanced Custom Studies" window: SC will automatically recognize "Visual C++ Path:" and then go to: Build --> Release All DLLs and Deny Load then go to: Build --> Build with C++ - Release That's it, I never had to run Visual Studio once, I don't know how to use it anyway. For Debian/Ubuntu Linux family: Install G++-mingw-w64-x86-64 first And then run a script something like this in a Old Post (#7): cp ~/.wine/drive_c/SierraChart/ACS_Source/*.h . x86_64-w64-mingw32-g++ -D _WIN64 -march=x86-64 -mtune=x86-64 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 MyCPPFile.cpp -o MyDLLFile.dll -Wno-deprecated &>Result.txt cp MyDLLFile.dll ~/.wine/drive_c/SierraChart/Data/ rm MyDLLFile.dll rm *.h Date Time Of Last Edit: 2023-03-10 02:27:53
[2023-03-10 04:09:59] |
An update caused an issue with remote building. The error has been identified and corrected. This issue is hereby resolved. Remote build error |
