Date/Time: Fri, 23 May 2025 11:20:57 +0000
you are so going to kill me
View Count: 419
[2023-03-07 16:32:02]
User849502 - Posts: 370
I went thru and can't find when we talked about getting data for the Brazil bond called the DI. I know that Denali does not have the Brazilian exchange but CQG does. I only want to use SC but can if my nephew absolutely wants charts of Brazil can we put cqg data into SC? I did look at the account section of help on SC and see CQG is an external source but I need help please...
this reply is going into the SC folder...
xx
[2023-03-07 17:58:20]
John - SC Support - Posts: 39996
You can get the CQG data for exchanges other than the CME Group and EUREX into Sierra Chart. So as long as you have the proper symbol and authorization for the exchange from CQG, then it should work just fine.
