Date/Time: Fri, 19 Apr 2024 15:53:04 +0000
issue with new version
View Count: 242
[2023-03-06 21:03:42] |
User357941 - Posts: 2 |
hi, I download directly your new version 2483 without removing the last i have 2443, when i want to connect i don't get my studies back and the server trie to connect with interactive brooker while i don't have an acount with them. appreciate |
[2023-03-06 22:17:30] |
John - SC Support - Posts: 30956 |
How exactly did you do the update? Do you perhaps have two separate installations of Sierra Chart now?
[2023-03-06 22:21:35] |
Yes I have two separate installation of Sierra chart now. Actually I can connect with my ID but I don’t find my studies on the new version |
[2023-03-06 22:31:46] |
Do you want to have two separate installations? If so, then refer to the following for how to copy the information from one installation to another: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Otherwise, remove the new one you just created and use the following instructions to update your original installation: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
