Date/Time: Fri, 29 Mar 2024 02:31:10 +0000
print screen shot
View Count: 1148
[2014-06-14 19:54:25] |
User88094 - Posts: 1 |
How does one print a screen shot?
[2014-06-16 06:19:30] |
Do you want to print a chart? If so, refer to the Print command documented here: http://www.sierrachart.com/index.php?l=doc/doc_FileMenu.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
