Date/Time: Thu, 28 Mar 2024 09:27:35 +0000
CancelAll button background does not work like Flatten/Reverse. Intentional?
View Count: 316
[2023-03-03 21:56:21] |
User719512 - Posts: 225 |
Hi Sierra, Is it intentional that the CancelAll button background only surrounds the Text and not the complete button? See attached image. |
Sierra v2484 CancelAll Button.png / V - Attached On 2023-03-03 21:55:49 UTC - Size: 106.91 KB - 53 views |
[2023-03-06 15:54:33] |
John - SC Support - Posts: 30399 |
In this case, the Cancel All is "inactive". This is because you do not have any working orders to cancel (or you have set the button to always be inactive). Once you have working orders on your chart, the Cancel All should be completely colored. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-06 20:38:55] |
I see that now. So related question is why doesn't the Flatten button work that same way if there are no positions to "Flatten"? Same could be said for Reverse. When flat, Reverse doesn't seem to apply either.
[2023-03-06 22:13:43] |
I do not know.
