Date/Time: Fri, 29 Mar 2024 12:28:25 +0000
Interactivebrokers _ No data between 16h / 19h
View Count: 2616
[2013-03-22 18:38:58] |
User73873 - Posts: 14 |
Hi, Today, on several charts, I have no data between 16h / 19h see the chart : http://www.sierrachart.com/image.php?l=1363977083271.png Can you explain to me why and how can i fix this problem ? Thank you |
cac problem 22 mars.png / V - Attached On 2013-03-22 18:34:52 UTC - Size: 68.58 KB - 553 views Attachment Deleted. Attachment Deleted. |
[2013-03-22 18:53:15] |
Refer to help topic 7 and 37 here: http://www.sierrachart.com/index.php?l=doc/helpdetails7.html http://www.sierrachart.com/index.php?l=doc/helpdetails37.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-22 20:41:02] |
Thanks, Everything is okay. Have a nice weekend |
[2013-05-02 09:24:40] |
I have a problem with my daily chart chart. It miss some candles (see chart). Idelete and download the data. But it doesn'it work. I read your help topic to fix the problem. Could you please help me to fix it ? Thanks |
YM-201306-ECBOT Daily #4 41396.3885.png / V - Attached On 2013-05-02 09:20:00 UTC - Size: 79.8 KB - 540 views GC-201306-NYMEX Daily #4 41396.389.png / V - Attached On 2013-05-02 09:20:28 UTC - Size: 47.86 KB - 527 views log sierra.JPG / V - Attached On 2013-05-02 09:20:52 UTC - Size: 114.42 KB - 510 views Attachment Deleted. |
[2013-05-02 16:38:41] |
Go to one of those charts , right-click before the missing bars and select Delete Data and Download. After that, please post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log If you still have a problem, also try temporarily disabling the firewall software you are running. The Windows firewall should not be causing a problem and does not need to be disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-06 07:12:59] |
Please find hereafter the chart of cac and the message log. Software version: 969 | 2013-05-06 08:52:27 Current Service Package: 5 | 2013-05-06 08:52:27 Usage end date: 2013-05-12 | 2013-05-06 08:52:27 Sierra Chart Historical Data Service is included. | 2013-05-06 08:52:27 Active service: Interactive Brokers | 2013-05-06 08:52:27 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2013-05-06 08:52:27 2013-05-06 08:52:27 Local computer clock time | 2013-05-06 08:52:27 2013-05-06 06:52:27 GMT time | 2013-05-06 08:52:27 2013-05-06 08:52:27 Time zone adjusted time | 2013-05-06 08:52:27 Time difference to server time: 2 seconds. | 2013-05-06 08:52:27 Program path: C:\SierraChart\ | 2013-05-06 08:52:27 Data Files path: C:\SierraChart\Data\ | 2013-05-06 08:52:27 OS Version Number: 6.1 | 2013-05-06 08:52:27 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 13:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-06 08:52:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 12:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-06 08:52:33 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 13:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-06 08:52:34 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 13:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-06 08:52:35 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 12:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-06 08:52:36 HD Request # 1 - Downloading Historical Daily chart data for AAPL. Starting date: 2013-05-01. Service: ddf | 2013-05-06 08:52:37 HD Request # 1 - Requesting historical Daily data for AAPL starting at 2013-04-30 | 2013-05-06 08:52:37 Connecting to IB data and trade server: localhost port 7496... | 2013-05-06 08:52:38 The network socket is connected. | 2013-05-06 08:52:38 Using client version 46. Waiting for acceptance... | 2013-05-06 08:52:38 TWS server version: 66 | 2013-05-06 08:52:38 Connected to IB data and trade server. | 2013-05-06 08:52:38 Next valid order ID: 1 | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:cusfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données de marché est OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données HMDS est OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données HMDS est OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données HMDS est OK:cashhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-06 08:52:38 Message from IB: La connection de données HMDS est OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2013-05-06 08:52:38 Next valid order ID: 1 | 2013-05-06 08:52:38 Starting updates for: CAC40-201305-MONEP | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: CAC40 SecType: FUT Exchange: MONEP Currency: | 2013-05-06 08:52:38 Subscribing to symbol: CAC40 SecType: FUT Exchange: MONEP Currency: | 2013-05-06 08:52:38 HD Request # 2 - Downloading Intraday chart data for CAC40-201305-MONEP to the file CAC40-201305-MONEP.scid. Service: ib | 2013-05-06 08:52:38 HD Request # 2 - Starting date and time: 2013-05-03 21:59:55 | 2013-05-06 08:52:38 HD Request # 2 - Requesting a total of 2 days and 43963 seconds. | 2013-05-06 08:52:38 HD Request # 2 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130363. | 2013-05-06 08:52:38 HD Request # 2 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:49:55 for CAC40-201305-MONEP | 2013-05-06 08:52:38 Starting updates for: YM-201306-ECBOT | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: YM SecType: FUT Exchange: ECBOT Currency: | 2013-05-06 08:52:38 Subscribing to symbol: YM SecType: FUT Exchange: ECBOT Currency: | 2013-05-06 08:52:38 Starting updates for: EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: EUR.USD SecType: CASH Exchange: IDEALPRO Currency: USD | 2013-05-06 08:52:38 Subscribing to symbol: EUR.USD SecType: CASH Exchange: IDEALPRO Currency: USD | 2013-05-06 08:52:38 Starting updates for: ES-201306-GLOBEX | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2013-05-06 08:52:38 Subscribing to symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2013-05-06 08:52:38 Starting updates for: GC-201306-NYMEX | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: GC SecType: FUT Exchange: NYMEX Currency: | 2013-05-06 08:52:38 Subscribing to symbol: GC SecType: FUT Exchange: NYMEX Currency: | 2013-05-06 08:52:38 Starting updates for: EUR-201306-GLOBEX | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: EUR SecType: FUT Exchange: GLOBEX Currency: | 2013-05-06 08:52:38 Subscribing to symbol: EUR SecType: FUT Exchange: GLOBEX Currency: | 2013-05-06 08:52:38 Starting updates for: GBL-201306-DTB | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: GBL SecType: FUT Exchange: DTB Currency: | 2013-05-06 08:52:38 Subscribing to symbol: GBL SecType: FUT Exchange: DTB Currency: | 2013-05-06 08:52:38 Starting updates for: INDU-I-NYSE | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: INDU SecType: IND Exchange: NYSE Currency: | 2013-05-06 08:52:38 Subscribing to symbol: INDU SecType: IND Exchange: NYSE Currency: | 2013-05-06 08:52:38 Starting updates for: NG-201306-NYMEX | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-06 08:52:38 Subscribing to symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-06 08:52:38 Starting updates for: NG-201305-NYMEX | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-06 08:52:38 Subscribing to symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-06 08:52:38 Starting updates for: $TICK | 2013-05-06 08:52:38 SC Index Data: Connecting to the market data server. | 2013-05-06 08:52:38 Using server: ds4.sierracharts.com, port 443 | 2013-05-06 08:52:38 SC Index Data - Local market data port: 0 | 2013-05-06 08:52:38 HD Request # 1 - Receiving historical Daily data for AAPL starting at 2013-04-30 | 2013-05-06 08:52:38 Writing historical daily data for AAPL to the file AAPL.dly | 2013-05-06 08:52:38 HD Request # 1 - Received 4 records from 2013-04-30 00:00:00 to 2013-05-03 00:00:00 (4.0 days) and wrote 3 records for AAPL | 2013-05-06 08:52:38 HD Request # 1 - Daily download COMPLETE for AAPL | 2013-05-06 08:52:38 HD Request # 3 - Downloading Historical Daily chart data for YMM13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:38 HD Request # 3 - Requesting historical Daily data for YMM13 starting at 2013-05-01 | 2013-05-06 08:52:38 Starting updates for: ZN-201306-ECBOT | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: ZN SecType: FUT Exchange: ECBOT Currency: | 2013-05-06 08:52:38 Subscribing to symbol: ZN SecType: FUT Exchange: ECBOT Currency: | 2013-05-06 08:52:38 Starting updates for: AAPL | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: AAPL SecType: STK Exchange: SMART Currency: USD | 2013-05-06 08:52:38 Subscribing to symbol: AAPL SecType: STK Exchange: SMART Currency: USD | 2013-05-06 08:52:38 Starting updates for: ZB-201306-ECBOT | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: ZB SecType: FUT Exchange: ECBOT Currency: | 2013-05-06 08:52:38 Subscribing to symbol: ZB SecType: FUT Exchange: ECBOT Currency: | 2013-05-06 08:52:38 HD Request # 3 - Receiving historical Daily data for YMM13 starting at 2013-05-01 | 2013-05-06 08:52:38 Writing historical daily data for YMM13 to the file YMM13.dly | 2013-05-06 08:52:38 HD Request # 3 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for YMM13 | 2013-05-06 08:52:38 HD Request # 3 - Daily download COMPLETE for YMM13 | 2013-05-06 08:52:38 HD Request # 4 - Downloading Historical Daily chart data for GGM13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:38 HD Request # 4 - Requesting historical Daily data for GGM13 starting at 2013-05-01 | 2013-05-06 08:52:38 Symbol Error: NG-201305-NYMEX is unknown, unavailable, or improperly formatted. | 2013-05-06 08:52:38 Symbol Error: NG-201305-NYMEX is unknown, unavailable, or improperly formatted. | 2013-05-06 08:52:38 Starting updates for: DAX-I-DTB | 2013-05-06 08:52:38 Subscribing to real-time True Data for symbol: DAX SecType: IND Exchange: DTB Currency: | 2013-05-06 08:52:38 Subscribing to symbol: DAX SecType: IND Exchange: DTB Currency: | 2013-05-06 08:52:39 HD Request # 4 - Receiving historical Daily data for GGM13 starting at 2013-05-02 | 2013-05-06 08:52:39 Writing historical daily data for GGM13 to the file GGM13.dly | 2013-05-06 08:52:39 HD Request # 4 - Received 3 records from 2013-05-02 00:00:00 to 2013-05-06 00:00:00 (5.0 days) and wrote 3 records for GGM13 | 2013-05-06 08:52:39 HD Request # 4 - Daily download COMPLETE for GGM13 | 2013-05-06 08:52:39 HD Request # 5 - Downloading Historical Daily chart data for CAC40-201305-MONEP. Starting date: 2013-04-30. Service: ddf | 2013-05-06 08:52:39 HD Request # 5 - Requesting historical Daily data for CAC40-201305-MONEP starting at 2013-04-29 | 2013-05-06 08:52:39 The network socket is connected. | 2013-05-06 08:52:39 SC Index Data: Connected to market data server. Now authorizing. | 2013-05-06 08:52:39 HD Request # 2 - Processing historical data message from TWS | 2013-05-06 08:52:39 HD Request # 2 - Receiving Intraday data for CAC40-201305-MONEP starting at 2013-05-02 11:58:00 | 2013-05-06 08:52:39 HD Request # 2 - Received 2880 records and wrote 0 records from 2013-05-02 11:58:00 to 2013-05-03 21:59:30. | 2013-05-06 08:52:39 HTTP Request 4 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:52:39 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:52:39 HD Request # 5 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:52:39 HD Request # 5 - Received 0 records and wrote 0 records for CAC40-201305-MONEP | 2013-05-06 08:52:39 HD Request # 5 - Daily download COMPLETE for CAC40-201305-MONEP | 2013-05-06 08:52:39 HD Request # 6 - Downloading Historical Daily chart data for GBL-201306-DTB. Starting date: 2013-04-30. Service: ddf | 2013-05-06 08:52:39 HD Request # 6 - Requesting historical Daily data for GBL-201306-DTB starting at 2013-04-29 | 2013-05-06 08:52:39 SC Index Data: Connected. | 2013-05-06 08:52:39 Restarting real-time data updates for symbol: $TICK | 2013-05-06 08:52:39 Message from IB: Requête en temps réel invalide:No market data permissions for DTB IND. IB Error Code: 420. Request ID: 825711. | 2013-05-06 08:52:39 HTTP Request 5 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:52:39 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:52:39 HD Request # 6 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:52:39 HD Request # 6 - Received 0 records and wrote 0 records for GBL-201306-DTB | 2013-05-06 08:52:39 HD Request # 6 - Daily download COMPLETE for GBL-201306-DTB | 2013-05-06 08:52:39 HD Request # 7 - Downloading Historical Daily chart data for ZN-201306-ECBOT. Starting date: 2013-05-01. Service: ddf | 2013-05-06 08:52:39 HD Request # 7 - Requesting historical Daily data for ZN-201306-ECBOT starting at 2013-04-30 | 2013-05-06 08:52:39 Message from IB: La connection de données HMDS est OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2013-05-06 08:52:39 HTTP Request 6 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:52:39 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:52:39 HD Request # 7 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:52:39 HD Request # 7 - Received 0 records and wrote 0 records for ZN-201306-ECBOT | 2013-05-06 08:52:39 HD Request # 7 - Daily download COMPLETE for ZN-201306-ECBOT | 2013-05-06 08:52:39 HD Request # 8 - Downloading Historical Daily chart data for EUR-201306-GLOBEX. Starting date: 2013-05-01. Service: ddf | 2013-05-06 08:52:39 HD Request # 8 - Requesting historical Daily data for EUR-201306-GLOBEX starting at 2013-04-30 | 2013-05-06 08:52:39 HTTP Request 7 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:52:39 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:52:39 HD Request # 8 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:52:39 HD Request # 8 - Received 0 records and wrote 0 records for EUR-201306-GLOBEX | 2013-05-06 08:52:39 HD Request # 8 - Daily download COMPLETE for EUR-201306-GLOBEX | 2013-05-06 08:52:39 HD Request # 9 - Downloading Historical Daily chart data for GCM13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:39 HD Request # 9 - Requesting historical Daily data for GCM13 starting at 2013-05-01 | 2013-05-06 08:52:39 HD Request # 10 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: scsrv | 2013-05-06 08:52:39 HD Request # 10 - Starting date and time: 2013-05-03 22:04:59 | 2013-05-06 08:52:39 HD Request # 10 - Using server: ds3.sierracharts.com port 10049 | 2013-05-06 08:52:39 HD Request # 9 - Receiving historical Daily data for GCM13 starting at 2013-05-01 | 2013-05-06 08:52:39 Writing historical daily data for GCM13 to the file GCM13.dly | 2013-05-06 08:52:39 HD Request # 9 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for GCM13 | 2013-05-06 08:52:39 HD Request # 9 - Daily download COMPLETE for GCM13 | 2013-05-06 08:52:39 HD Request # 12 - Downloading Historical Daily chart data for ES-201306-GLOBEX. Starting date: 2013-05-01. Service: ddf | 2013-05-06 08:52:39 HD Request # 12 - Requesting historical Daily data for ES-201306-GLOBEX starting at 2013-04-30 | 2013-05-06 08:52:39 The network socket is connected. | 2013-05-06 08:52:40 HD Request # 10 - Requesting up to 90 days of Intraday data. | 2013-05-06 08:52:40 HTTP Request 9 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:52:40 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:52:40 HD Request # 12 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:52:40 HD Request # 12 - Received 0 records and wrote 0 records for ES-201306-GLOBEX | 2013-05-06 08:52:40 HD Request # 12 - Daily download COMPLETE for ES-201306-GLOBEX | 2013-05-06 08:52:40 HD Request # 13 - Downloading Historical Daily chart data for EUR.USD-CASH-IDEALPRO. Starting date: 2013-05-01. Service: ddf | 2013-05-06 08:52:40 HD Request # 13 - Requesting historical Daily data for EUR.USD-CASH-IDEALPRO starting at 2013-04-30 | 2013-05-06 08:52:40 HD Request # 13 - Received 0 records and wrote 0 records for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:40 HD Request # 13 - Daily download COMPLETE for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:40 HD Request # 14 - Downloading Historical Daily chart data for INDU-I-NYSE. Starting date: 2013-04-30. Service: ddf | 2013-05-06 08:52:40 HD Request # 14 - Requesting historical Daily data for INDU-I-NYSE starting at 2013-04-29 | 2013-05-06 08:52:40 HD Request # 14 - Received 0 records and wrote 0 records for INDU-I-NYSE | 2013-05-06 08:52:40 HD Request # 14 - Daily download COMPLETE for INDU-I-NYSE | 2013-05-06 08:52:40 HD Request # 15 - Downloading Historical Daily chart data for ESM13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:40 HD Request # 15 - Requesting historical Daily data for ESM13 starting at 2013-05-01 | 2013-05-06 08:52:40 HD Request # 15 - Receiving historical Daily data for ESM13 starting at 2013-05-01 | 2013-05-06 08:52:40 Writing historical daily data for ESM13 to the file ESM13.dly | 2013-05-06 08:52:40 HD Request # 15 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for ESM13 | 2013-05-06 08:52:40 HD Request # 15 - Daily download COMPLETE for ESM13 | 2013-05-06 08:52:40 HD Request # 16 - Downloading Historical Daily chart data for ^EURUSD. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:40 HD Request # 16 - Requesting historical Daily data for ^EURUSD starting at 2013-05-01 | 2013-05-06 08:52:40 HD Request # 10 - Decompressing data. | 2013-05-06 08:52:40 HD Request # 10 - Receiving Intraday data for $TICK starting at 2013-05-03 22:04:59 | 2013-05-06 08:52:40 HD Request # 10 - Timestamp of first Intraday data file record written: 2013-05-03 22:04:59 | 2013-05-06 08:52:40 Socket closed. No error. | 2013-05-06 08:52:40 HD Request # 10 - Received 1 record from 2013-05-03 22:04:59 to 2013-05-03 22:04:59 (0.0 seconds) and wrote 1 record for $TICK | 2013-05-06 08:52:40 HD Request # 10 - Intraday download COMPLETE for $TICK | 2013-05-06 08:52:40 Real-time intraday chart data file updates started for $TICK | 2013-05-06 08:52:40 HD Request # 16 - Receiving historical Daily data for ^EURUSD starting at 2013-05-01 | 2013-05-06 08:52:40 Writing historical daily data for ^EURUSD to the file ^EURUSD.dly | 2013-05-06 08:52:40 HD Request # 16 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for ^EURUSD | 2013-05-06 08:52:40 HD Request # 16 - Daily download COMPLETE for ^EURUSD | 2013-05-06 08:52:40 HD Request # 17 - Downloading Historical Daily chart data for E6M13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:40 HD Request # 17 - Requesting historical Daily data for E6M13 starting at 2013-05-01 | 2013-05-06 08:52:40 HD Request # 17 - Receiving historical Daily data for E6M13 starting at 2013-05-01 | 2013-05-06 08:52:41 Writing historical daily data for E6M13 to the file E6M13.dly | 2013-05-06 08:52:41 HD Request # 17 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for E6M13 | 2013-05-06 08:52:41 HD Request # 17 - Daily download COMPLETE for E6M13 | 2013-05-06 08:52:41 HD Request # 18 - Downloading Historical Daily chart data for ZBM13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:41 HD Request # 18 - Requesting historical Daily data for ZBM13 starting at 2013-05-01 | 2013-05-06 08:52:41 HD Request # 18 - Receiving historical Daily data for ZBM13 starting at 2013-05-01 | 2013-05-06 08:52:41 Writing historical daily data for ZBM13 to the file ZBM13.dly | 2013-05-06 08:52:41 HD Request # 18 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for ZBM13 | 2013-05-06 08:52:41 HD Request # 18 - Daily download COMPLETE for ZBM13 | 2013-05-06 08:52:41 HD Request # 19 - Downloading Historical Daily chart data for DYY0. Starting date: 2013-04-30. Service: ddf | 2013-05-06 08:52:41 HD Request # 19 - Requesting historical Daily data for DYY0 starting at 2013-04-29 | 2013-05-06 08:52:41 HD Request # 19 - Receiving historical Daily data for DYY0 starting at 2013-04-29 | 2013-05-06 08:52:41 Writing historical daily data for DYY0 to the file DYY0.dly | 2013-05-06 08:52:41 HD Request # 19 - Received 4 records from 2013-04-29 00:00:00 to 2013-05-03 00:00:00 (5.0 days) and wrote 3 records for DYY0 | 2013-05-06 08:52:41 HD Request # 19 - Daily download COMPLETE for DYY0 | 2013-05-06 08:52:41 HD Request # 20 - Downloading Historical Daily chart data for $DOWI. Starting date: 2013-05-01. Service: ddf | 2013-05-06 08:52:41 HD Request # 20 - Requesting historical Daily data for $DOWI starting at 2013-04-30 | 2013-05-06 08:52:41 HD Request # 20 - Receiving historical Daily data for $DOWI starting at 2013-04-30 | 2013-05-06 08:52:41 Writing historical daily data for $DOWI to the file $DOWI.dly | 2013-05-06 08:52:41 HD Request # 20 - Received 4 records from 2013-04-30 00:00:00 to 2013-05-03 00:00:00 (4.0 days) and wrote 3 records for $DOWI | 2013-05-06 08:52:41 HD Request # 20 - Daily download COMPLETE for $DOWI | 2013-05-06 08:52:41 HD Request # 21 - Downloading Historical Daily chart data for NGK13. Starting date: 2013-04-25. Service: ddf | 2013-05-06 08:52:41 HD Request # 21 - Requesting historical Daily data for NGK13 starting at 2013-04-24 | 2013-05-06 08:52:41 HD Request # 2 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43963. | 2013-05-06 08:52:41 HD Request # 2 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:49:55 for CAC40-201305-MONEP | 2013-05-06 08:52:41 HD Request # 21 - Receiving historical Daily data for NGK13 starting at 2013-04-24 | 2013-05-06 08:52:41 Writing historical daily data for NGK13 to the file NGK13.dly | 2013-05-06 08:52:41 HD Request # 21 - Received 3 records from 2013-04-24 00:00:00 to 2013-04-26 00:00:00 (3.0 days) and wrote 2 records for NGK13 | 2013-05-06 08:52:42 HD Request # 21 - Daily download COMPLETE for NGK13 | 2013-05-06 08:52:42 HD Request # 22 - Downloading Historical Daily chart data for NGM13. Starting date: 2013-05-02. Service: ddf | 2013-05-06 08:52:42 HD Request # 22 - Requesting historical Daily data for NGM13 starting at 2013-05-01 | 2013-05-06 08:52:42 HD Request # 22 - Receiving historical Daily data for NGM13 starting at 2013-05-01 | 2013-05-06 08:52:42 Writing historical daily data for NGM13 to the file NGM13.dly | 2013-05-06 08:52:42 HD Request # 22 - Received 4 records from 2013-05-01 00:00:00 to 2013-05-06 00:00:00 (6.0 days) and wrote 3 records for NGM13 | 2013-05-06 08:52:42 HD Request # 22 - Daily download COMPLETE for NGM13 | 2013-05-06 08:52:42 HD Request # 2 - Processing historical data message from TWS | 2013-05-06 08:52:42 HD Request # 2 - Received 2880 records and wrote 0 records from 2013-05-02 11:58:00 to 2013-05-03 21:59:30. | 2013-05-06 08:52:42 IB Trading service: Requesting Trade Positions for account: | 2013-05-06 08:52:43 IB Trading service: Received Trade Positions download end message. | 2013-05-06 08:52:43 HD Request # 2 - IB Backfill - Seconds requested: 43963. Seconds Remaining: 0. | 2013-05-06 08:52:44 HD Request # 2 - Requesting 43963 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:02:38 for CAC40-201305-MONEP | 2013-05-06 08:52:44 HD Request # 2 - Processing historical data message from TWS | 2013-05-06 08:52:45 HD Request # 2 - Timestamp of first Intraday data file record written: 2013-05-06 08:00:00 | 2013-05-06 08:52:45 HD Request # 2 - Received 1327 records and wrote 106 records from 2013-05-03 11:48:30 to 2013-05-06 08:52:30. | 2013-05-06 08:52:45 HD Request # 2 - Received 7087 records from 2013-05-02 11:58:00 to 2013-05-06 08:52:30 (3.9 days) and wrote 106 records for CAC40-201305-MONEP | 2013-05-06 08:52:47 HD Request # 2 - Intraday download COMPLETE for CAC40-201305-MONEP | 2013-05-06 08:52:47 Real-time intraday chart data file updates started for CAC40-201305-MONEP | 2013-05-06 08:52:47 HD Request # 23 - Downloading Intraday chart data for EUR.USD-CASH-IDEALPRO to the file EUR.USD-CASH-IDEALPRO.scid. Service: ib | 2013-05-06 08:52:47 HD Request # 23 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:52:47 HD Request # 23 - Requesting a total of 2 days and 43602 seconds. | 2013-05-06 08:52:47 HD Request # 23 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130002. | 2013-05-06 08:52:47 HD Request # 23 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:47 HD Request # 23 - Processing historical data message from TWS | 2013-05-06 08:52:48 HD Request # 23 - Receiving Intraday data for EUR.USD-CASH-IDEALPRO starting at 2013-05-02 22:45:00 | 2013-05-06 08:52:48 HD Request # 23 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:52:48 HD Request # 23 - Received 2880 records and wrote 107 records from 2013-05-02 22:45:00 to 2013-05-03 22:59:30. | 2013-05-06 08:52:48 HD Request # 23 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43602. | 2013-05-06 08:52:50 HD Request # 23 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:50 HD Request # 23 - Processing historical data message from TWS | 2013-05-06 08:52:51 HD Request # 23 - Received 2880 records and wrote 0 records from 2013-05-02 22:45:00 to 2013-05-03 22:59:30. | 2013-05-06 08:52:51 HD Request # 23 - IB Backfill - Seconds requested: 43602. Seconds Remaining: 0. | 2013-05-06 08:52:54 HD Request # 23 - Requesting 43602 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:02:47 for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:54 HD Request # 23 - Processing historical data message from TWS | 2013-05-06 08:52:54 HD Request # 23 - Received 1314 records and wrote 1156 records from 2013-05-03 21:41:00 to 2013-05-06 08:52:30. | 2013-05-06 08:52:54 HD Request # 23 - Received 7074 records from 2013-05-02 22:45:00 to 2013-05-06 08:52:30 (3.4 days) and wrote 1263 records for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:57 HD Request # 23 - Intraday download COMPLETE for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:57 Real-time intraday chart data file updates started for EUR.USD-CASH-IDEALPRO | 2013-05-06 08:52:57 HD Request # 24 - Downloading Intraday chart data for GC-201306-NYMEX to the file GC-201306-NYMEX.scid. Service: ib | 2013-05-06 08:52:57 HD Request # 24 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:52:57 HD Request # 24 - Requesting a total of 2 days and 43612 seconds. | 2013-05-06 08:52:57 HD Request # 24 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130012. | 2013-05-06 08:52:57 HD Request # 24 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for GC-201306-NYMEX | 2013-05-06 08:52:57 HD Request # 24 - Processing historical data message from TWS | 2013-05-06 08:52:57 HD Request # 24 - Receiving Intraday data for GC-201306-NYMEX starting at 2013-05-02 22:30:00 | 2013-05-06 08:52:57 HD Request # 24 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:52:57 HD Request # 24 - Received 2880 records and wrote 137 records from 2013-05-02 22:30:00 to 2013-05-03 23:14:30. | 2013-05-06 08:52:57 HD Request # 24 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43612. | 2013-05-06 08:53:00 HD Request # 24 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for GC-201306-NYMEX | 2013-05-06 08:53:00 HD Request # 24 - Processing historical data message from TWS | 2013-05-06 08:53:01 HD Request # 24 - Received 2880 records and wrote 0 records from 2013-05-02 22:30:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:01 HD Request # 24 - IB Backfill - Seconds requested: 43612. Seconds Remaining: 0. | 2013-05-06 08:53:03 HD Request # 24 - Requesting 43612 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:02:57 for GC-201306-NYMEX | 2013-05-06 08:53:03 HD Request # 24 - Processing historical data message from TWS | 2013-05-06 08:53:04 HD Request # 24 - Received 1315 records and wrote 1067 records from 2013-05-03 21:11:00 to 2013-05-06 08:53:00. | 2013-05-06 08:53:04 HD Request # 24 - Received 7075 records from 2013-05-02 22:30:00 to 2013-05-06 08:53:00 (3.4 days) and wrote 1204 records for GC-201306-NYMEX | 2013-05-06 08:53:06 HD Request # 24 - Intraday download COMPLETE for GC-201306-NYMEX | 2013-05-06 08:53:06 Real-time intraday chart data file updates started for GC-201306-NYMEX | 2013-05-06 08:53:06 HD Request # 25 - Downloading Intraday chart data for YM-201306-ECBOT to the file YM-201306-ECBOT.scid. Service: ib | 2013-05-06 08:53:06 HD Request # 25 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:53:06 HD Request # 25 - Requesting a total of 2 days and 43621 seconds. | 2013-05-06 08:53:06 HD Request # 25 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130021. | 2013-05-06 08:53:06 HD Request # 25 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for YM-201306-ECBOT | 2013-05-06 08:53:06 HD Request # 25 - Processing historical data message from TWS | 2013-05-06 08:53:07 HD Request # 25 - Receiving Intraday data for YM-201306-ECBOT starting at 2013-05-02 22:00:00 | 2013-05-06 08:53:07 HD Request # 25 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:53:07 HD Request # 25 - Received 2880 records and wrote 107 records from 2013-05-02 22:00:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:07 HD Request # 25 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43621. | 2013-05-06 08:53:10 HD Request # 25 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for YM-201306-ECBOT | 2013-05-06 08:53:10 HD Request # 25 - Processing historical data message from TWS | 2013-05-06 08:53:10 HD Request # 25 - Received 2880 records and wrote 0 records from 2013-05-02 22:00:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:10 HD Request # 25 - IB Backfill - Seconds requested: 43621. Seconds Remaining: 0. | 2013-05-06 08:53:13 HD Request # 25 - Requesting 43621 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:03:06 for YM-201306-ECBOT | 2013-05-06 08:53:13 HD Request # 25 - Processing historical data message from TWS | 2013-05-06 08:53:13 HD Request # 25 - Received 1315 records and wrote 1067 records from 2013-05-03 20:56:00 to 2013-05-06 08:53:00. | 2013-05-06 08:53:13 HD Request # 25 - Received 7075 records from 2013-05-02 22:00:00 to 2013-05-06 08:53:00 (3.5 days) and wrote 1174 records for YM-201306-ECBOT | 2013-05-06 08:53:16 HD Request # 25 - Intraday download COMPLETE for YM-201306-ECBOT | 2013-05-06 08:53:16 Real-time intraday chart data file updates started for YM-201306-ECBOT | 2013-05-06 08:53:16 HD Request # 26 - Downloading Intraday chart data for ES-201306-GLOBEX to the file ES-201306-GLOBEX.scid. Service: ib | 2013-05-06 08:53:16 HD Request # 26 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:53:16 HD Request # 26 - Requesting a total of 2 days and 43631 seconds. | 2013-05-06 08:53:16 HD Request # 26 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130031. | 2013-05-06 08:53:16 HD Request # 26 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for ES-201306-GLOBEX | 2013-05-06 08:53:16 HD Request # 26 - Processing historical data message from TWS | 2013-05-06 08:53:16 HD Request # 26 - Receiving Intraday data for ES-201306-GLOBEX starting at 2013-05-02 22:00:00 | 2013-05-06 08:53:16 HD Request # 26 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:53:16 HD Request # 26 - Received 2880 records and wrote 107 records from 2013-05-02 22:00:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:16 HD Request # 26 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43631. | 2013-05-06 08:53:19 HD Request # 26 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for ES-201306-GLOBEX | 2013-05-06 08:53:19 HD Request # 26 - Processing historical data message from TWS | 2013-05-06 08:53:20 HD Request # 26 - Received 2880 records and wrote 0 records from 2013-05-02 22:00:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:20 HD Request # 26 - IB Backfill - Seconds requested: 43631. Seconds Remaining: 0. | 2013-05-06 08:53:22 HD Request # 26 - Requesting 43631 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:03:16 for ES-201306-GLOBEX | 2013-05-06 08:53:22 HD Request # 26 - Processing historical data message from TWS | 2013-05-06 08:53:23 HD Request # 26 - Received 1315 records and wrote 1067 records from 2013-05-03 20:56:00 to 2013-05-06 08:53:00. | 2013-05-06 08:53:23 HD Request # 26 - Received 7075 records from 2013-05-02 22:00:00 to 2013-05-06 08:53:00 (3.5 days) and wrote 1174 records for ES-201306-GLOBEX | 2013-05-06 08:53:25 HD Request # 26 - Intraday download COMPLETE for ES-201306-GLOBEX | 2013-05-06 08:53:25 Real-time intraday chart data file updates started for ES-201306-GLOBEX | 2013-05-06 08:53:25 HD Request # 27 - Downloading Intraday chart data for EUR-201306-GLOBEX to the file EUR-201306-GLOBEX.scid. Service: ib | 2013-05-06 08:53:25 HD Request # 27 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:53:25 HD Request # 27 - Requesting a total of 2 days and 43640 seconds. | 2013-05-06 08:53:25 HD Request # 27 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130040. | 2013-05-06 08:53:25 HD Request # 27 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for EUR-201306-GLOBEX | 2013-05-06 08:53:25 HD Request # 27 - Processing historical data message from TWS | 2013-05-06 08:53:26 HD Request # 27 - Receiving Intraday data for EUR-201306-GLOBEX starting at 2013-05-02 22:00:00 | 2013-05-06 08:53:26 HD Request # 27 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:53:26 HD Request # 27 - Received 2880 records and wrote 107 records from 2013-05-02 22:00:00 to 2013-05-03 22:59:30. | 2013-05-06 08:53:26 HD Request # 27 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43640. | 2013-05-06 08:53:28 HD Request # 27 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for EUR-201306-GLOBEX | 2013-05-06 08:53:28 HD Request # 27 - Processing historical data message from TWS | 2013-05-06 08:53:29 HD Request # 27 - Received 2880 records and wrote 0 records from 2013-05-02 22:00:00 to 2013-05-03 22:59:30. | 2013-05-06 08:53:29 HD Request # 27 - IB Backfill - Seconds requested: 43640. Seconds Remaining: 0. | 2013-05-06 08:53:32 HD Request # 27 - Requesting 43640 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:03:25 for EUR-201306-GLOBEX | 2013-05-06 08:53:32 HD Request # 27 - Processing historical data message from TWS | 2013-05-06 08:53:32 HD Request # 27 - Received 1315 records and wrote 1067 records from 2013-05-03 20:56:00 to 2013-05-06 08:53:00. | 2013-05-06 08:53:32 HD Request # 27 - Received 7075 records from 2013-05-02 22:00:00 to 2013-05-06 08:53:00 (3.5 days) and wrote 1174 records for EUR-201306-GLOBEX | 2013-05-06 08:53:35 HD Request # 27 - Intraday download COMPLETE for EUR-201306-GLOBEX | 2013-05-06 08:53:35 Real-time intraday chart data file updates started for EUR-201306-GLOBEX | 2013-05-06 08:53:35 HD Request # 28 - Downloading Intraday chart data for GBL-201306-DTB to the file GBL-201306-DTB.scid. Service: ib | 2013-05-06 08:53:35 HD Request # 28 - Starting date and time: 2013-05-03 22:04:55 | 2013-05-06 08:53:35 HD Request # 28 - Requesting a total of 2 days and 43720 seconds. | 2013-05-06 08:53:35 HD Request # 28 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130120. | 2013-05-06 08:53:35 HD Request # 28 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:54:55 for GBL-201306-DTB | 2013-05-06 08:53:35 HD Request # 28 - Processing historical data message from TWS | 2013-05-06 08:53:35 HD Request # 28 - Receiving Intraday data for GBL-201306-DTB starting at 2013-05-02 12:10:00 | 2013-05-06 08:53:35 HD Request # 28 - Received 2878 records and wrote 0 records from 2013-05-02 12:10:00 to 2013-05-03 22:04:30. | 2013-05-06 08:53:35 HD Request # 28 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43720. | 2013-05-06 08:53:38 HD Request # 28 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:54:55 for GBL-201306-DTB | 2013-05-06 08:53:38 HD Request # 28 - Processing historical data message from TWS | 2013-05-06 08:53:38 HD Request # 28 - Received 2878 records and wrote 0 records from 2013-05-02 12:10:00 to 2013-05-03 22:04:30. | 2013-05-06 08:53:38 HD Request # 28 - IB Backfill - Seconds requested: 43720. Seconds Remaining: 0. | 2013-05-06 08:53:41 HD Request # 28 - Requesting 43720 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:03:35 for GBL-201306-DTB | 2013-05-06 08:53:41 HD Request # 28 - Processing historical data message from TWS | 2013-05-06 08:53:41 HD Request # 28 - Timestamp of first Intraday data file record written: 2013-05-06 08:01:00 | 2013-05-06 08:53:41 HD Request # 28 - Received 1317 records and wrote 106 records from 2013-05-03 11:59:30 to 2013-05-06 08:53:30. | 2013-05-06 08:53:41 HD Request # 28 - Received 7073 records from 2013-05-02 12:10:00 to 2013-05-06 08:53:30 (3.9 days) and wrote 106 records for GBL-201306-DTB | 2013-05-06 08:53:44 HD Request # 28 - Intraday download COMPLETE for GBL-201306-DTB | 2013-05-06 08:53:44 Real-time intraday chart data file updates started for GBL-201306-DTB | 2013-05-06 08:53:44 HD Request # 29 - Downloading Intraday chart data for NG-201306-NYMEX to the file NG-201306-NYMEX.scid. Service: ib | 2013-05-06 08:53:44 HD Request # 29 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:53:44 HD Request # 29 - Requesting a total of 2 days and 43659 seconds. | 2013-05-06 08:53:44 HD Request # 29 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130059. | 2013-05-06 08:53:44 HD Request # 29 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for NG-201306-NYMEX | 2013-05-06 08:53:44 HD Request # 29 - Processing historical data message from TWS | 2013-05-06 08:53:45 HD Request # 29 - Receiving Intraday data for NG-201306-NYMEX starting at 2013-05-02 22:30:00 | 2013-05-06 08:53:45 HD Request # 29 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:53:45 HD Request # 29 - Received 2880 records and wrote 137 records from 2013-05-02 22:30:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:45 HD Request # 29 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43659. | 2013-05-06 08:53:47 HD Request # 29 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for NG-201306-NYMEX | 2013-05-06 08:53:47 HD Request # 29 - Processing historical data message from TWS | 2013-05-06 08:53:48 HD Request # 29 - Received 2880 records and wrote 0 records from 2013-05-02 22:30:00 to 2013-05-03 23:14:30. | 2013-05-06 08:53:48 HD Request # 29 - IB Backfill - Seconds requested: 43659. Seconds Remaining: 0. | 2013-05-06 08:53:50 HD Request # 29 - Requesting 43659 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:03:44 for NG-201306-NYMEX | 2013-05-06 08:53:50 HD Request # 29 - Processing historical data message from TWS | 2013-05-06 08:53:51 HD Request # 29 - Received 1316 records and wrote 1068 records from 2013-05-03 21:11:00 to 2013-05-06 08:53:30. | 2013-05-06 08:53:51 HD Request # 29 - Received 7076 records from 2013-05-02 22:30:00 to 2013-05-06 08:53:30 (3.4 days) and wrote 1205 records for NG-201306-NYMEX | 2013-05-06 08:53:53 HD Request # 29 - Intraday download COMPLETE for NG-201306-NYMEX | 2013-05-06 08:53:53 Real-time intraday chart data file updates started for NG-201306-NYMEX | 2013-05-06 08:53:53 HD Request # 30 - Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ib | 2013-05-06 08:53:53 HD Request # 30 - Starting date and time: 2013-05-03 22:06:05 | 2013-05-06 08:53:53 HD Request # 30 - Requesting a total of 2 days and 43668 seconds. | 2013-05-06 08:53:53 HD Request # 30 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130068. | 2013-05-06 08:53:53 HD Request # 30 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:56:05 for AAPL | 2013-05-06 08:53:53 HD Request # 30 - Processing historical data message from TWS | 2013-05-06 08:53:54 HD Request # 30 - Receiving Intraday data for AAPL starting at 2013-05-02 18:00:00 | 2013-05-06 08:53:54 HD Request # 30 - Timestamp of first Intraday data file record written: 2013-05-03 22:06:30 | 2013-05-06 08:53:54 HD Request # 30 - Received 2873 records and wrote 467 records from 2013-05-02 18:00:00 to 2013-05-04 01:59:30. | 2013-05-06 08:53:54 HD Request # 30 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 43668. | 2013-05-06 08:53:56 HD Request # 30 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:56:05 for AAPL | 2013-05-06 08:53:56 HD Request # 30 - Processing historical data message from TWS | 2013-05-06 08:53:57 HD Request # 30 - Received 2873 records and wrote 0 records from 2013-05-02 18:00:00 to 2013-05-04 01:59:30. | 2013-05-06 08:53:57 HD Request # 30 - IB Backfill - Seconds requested: 43668. Seconds Remaining: 0. | 2013-05-06 08:54:00 HD Request # 30 - Requesting 43668 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:03:53 for AAPL | 2013-05-06 08:54:00 HD Request # 30 - Processing historical data message from TWS | 2013-05-06 08:54:00 HD Request # 30 - Received 1448 records and wrote 0 records from 2013-05-03 13:56:00 to 2013-05-04 01:59:30. | 2013-05-06 08:54:00 HD Request # 30 - Received 7194 records from 2013-05-02 18:00:00 to 2013-05-04 01:59:30 (32.0 hours) and wrote 467 records for AAPL | 2013-05-06 08:54:03 HD Request # 30 - Intraday download COMPLETE for AAPL | 2013-05-06 08:54:03 Real-time intraday chart data file updates started for AAPL | 2013-05-06 08:54:03 HD Request # 31 - Downloading Intraday chart data for INDU-I-NYSE to the file INDU-I-NYSE.scid. Service: ib | 2013-05-06 08:54:03 HD Request # 31 - Starting date and time: 2013-05-03 21:59:55 | 2013-05-06 08:54:03 HD Request # 31 - Requesting a total of 2 days and 44048 seconds. | 2013-05-06 08:54:03 HD Request # 31 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 130448. | 2013-05-06 08:54:03 HD Request # 31 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-04 21:49:55 for INDU-I-NYSE | 2013-05-06 08:54:03 HD Request # 31 - Processing historical data message from TWS | 2013-05-06 08:54:03 HD Request # 31 - Receiving Intraday data for INDU-I-NYSE starting at 2013-04-30 17:30:00 | 2013-05-06 08:54:03 HD Request # 31 - Received 2880 records and wrote 0 records from 2013-04-30 17:30:00 to 2013-05-03 21:59:30. | 2013-05-06 08:54:03 HD Request # 31 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 44048. | 2013-05-06 08:54:06 HD Request # 31 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2013-05-05 21:49:55 for INDU-I-NYSE | 2013-05-06 08:54:06 HD Request # 31 - Processing historical data message from TWS | 2013-05-06 08:54:06 HD Request # 31 - Received 2880 records and wrote 0 records from 2013-04-30 17:30:00 to 2013-05-03 21:59:30. | 2013-05-06 08:54:06 HD Request # 31 - IB Backfill - Seconds requested: 44048. Seconds Remaining: 0. | 2013-05-06 08:54:09 HD Request # 31 - Requesting 44048 Seconds of data at 30 secs with ending Date-Time at 2013-05-06 10:04:03 for INDU-I-NYSE | 2013-05-06 08:54:09 HD Request # 31 - Processing historical data message from TWS | 2013-05-06 08:54:09 HD Request # 31 - Received 1469 records and wrote 0 records from 2013-05-02 16:15:30 to 2013-05-03 21:59:30. | 2013-05-06 08:54:09 HD Request # 31 - Received 7229 records from 2013-04-30 17:30:00 to 2013-05-03 21:59:30 (3.2 days) and wrote 0 records for INDU-I-NYSE | 2013-05-06 08:54:12 HD Request # 31 - Intraday download COMPLETE for INDU-I-NYSE | 2013-05-06 08:54:12 Real-time intraday chart data file updates started for INDU-I-NYSE | 2013-05-06 08:54:12 HD Request # 32 - Downloading Historical Daily chart data for CAC40-201305-MONEP. Starting date: 2013-05-06. Service: ddf | 2013-05-06 08:57:35 HD Request # 32 - Requesting historical Daily data for CAC40-201305-MONEP starting at 2013-05-05 | 2013-05-06 08:57:35 HTTP Request 20 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:57:35 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:57:35 HD Request # 32 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:57:35 HD Request # 32 - Received 0 records and wrote 0 records for CAC40-201305-MONEP | 2013-05-06 08:57:35 HD Request # 32 - Daily download COMPLETE for CAC40-201305-MONEP | 2013-05-06 08:57:35 HD Request # 33 - Downloading Historical Daily chart data for CAC40-201305-MONEP. Starting date: 2013-04-18. Service: ddf | 2013-05-06 08:58:09 HD Request # 33 - Requesting historical Daily data for CAC40-201305-MONEP starting at 2013-04-17 | 2013-05-06 08:58:09 HTTP Request 21 Inflate Error: There's an error in the data. Zlib message: invalid distance too far back | 2013-05-06 08:58:09 Technical Notice: Compressed buffer size is not zero at the end of data in c_HTTPRequest::OnInternetStatusRequestComplete. | 2013-05-06 08:58:09 HD Request # 33 - Error received when downloading from the SC Historical Data service: Error executing query: Invalid symbol_ | 2013-05-06 08:58:09 HD Request # 33 - Received 0 records and wrote 0 records for CAC40-201305-MONEP | 2013-05-06 08:58:09 HD Request # 33 - Daily download COMPLETE for CAC40-201305-MONEP | 2013-05-06 08:58:09 The chart image has been saved to: C:\SierraChart\Images\CAC40-201305-MONEP Daily #7 41400.2906.png | 2013-05-06 08:58:28 Reloading Historical chart for $DOWI because new session daily quote data is detected. | 2013-05-06 08:59:33 Reloading Historical chart for INDU-I-NYSE because new session daily quote data is detected. | 2013-05-06 08:59:33 Reloading Historical chart for INDU-I-NYSE because new session daily quote data is detected. | 2013-05-06 08:59:33 Reloading Historical chart for INDU-I-NYSE because new session daily quote data is detected. | 2013-05-06 08:59:33 Reloading Historical chart for INDU-I-NYSE because new session daily quote data is detected. | 2013-05-06 08:59:33 Reloading Historical chart for INDU-I-NYSE because new session daily quote data is detected. | 2013-05-06 08:59:33 |
CAC40-201305-MONEP Daily #7 41400.2906.png / V - Attached On 2013-05-06 07:11:27 UTC - Size: 65.8 KB - 538 views |
[2013-05-06 23:08:20] |
We see that you have specified to use the Sierra Chart Historical Data Service for historical Daily data. The symbols are different for this service. We see many of your Historical Charts are not updating properly. These are 2 of them: GBL-201306-DTB CAC40-201305-MONEP We have made certain there are proper symbol settings for the symbols of the Historical charts that you are using. To get the updated settings, restart Sierra Chart. For Historical Charts that are missing bars, you need to go to File >> Find Symbol to open new charts for them. By doing this, the symbols will be properly set in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-08 12:48:10] |
"To get the updated settings, restart Sierra Chart. For Historical Charts that are missing bars, you need to go to File >> Find Symbol to open new charts for them. By doing this, the symbols will be properly set in the chart." I followed your advice but it didn't fix my problem. Do you have another idea ? Thanks |
[2013-05-08 16:49:51] |
Restart Sierra Chart. Open a new Historical Chart for a symbol you previously had a problem with and then post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-08 16:58:58] |
Thank you for your answer. All my daily charts doesn't work. Please find hereafter an example attached and the log Software version: 969 | 2013-05-08 18:54:08 Current Service Package: 5 | 2013-05-08 18:54:08 Usage end date: 2013-05-12 | 2013-05-08 18:54:08 Sierra Chart Historical Data Service is included. | 2013-05-08 18:54:08 Active service: Interactive Brokers | 2013-05-08 18:54:08 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2013-05-08 18:54:08 2013-05-08 18:54:08 Local computer clock time | 2013-05-08 18:54:08 2013-05-08 16:54:08 GMT time | 2013-05-08 18:54:08 2013-05-08 18:54:08 Time zone adjusted time | 2013-05-08 18:54:08 Time difference to server time: 6 seconds. | 2013-05-08 18:54:08 Program path: C:\SierraChart\ | 2013-05-08 18:54:08 Data Files path: C:\SierraChart\Data\ | 2013-05-08 18:54:08 OS Version Number: 6.1 | 2013-05-08 18:54:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 13:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-08 18:54:12 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 12:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-08 18:54:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 12:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-08 18:54:15 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-04 08:00:00. Current Date Time: 2013-03-01 12:00:00. Filename: C:\SierraChart\Data\GBL-201306-DTB.scid | 2013-05-08 18:54:16 Connecting to IB data and trade server: localhost port 7496... | 2013-05-08 18:54:18 The network socket is connected. | 2013-05-08 18:54:18 Using client version 46. Waiting for acceptance... | 2013-05-08 18:54:18 TWS server version: 66 | 2013-05-08 18:54:18 Connected to IB data and trade server. | 2013-05-08 18:54:18 Next valid order ID: 1 | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données de marché est OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données HMDS est OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données HMDS est OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données HMDS est OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données HMDS est OK:cashhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-08 18:54:18 Message from IB: La connection de données HMDS est OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2013-05-08 18:54:18 Next valid order ID: 1 | 2013-05-08 18:54:18 Starting updates for: GBL-201306-DTB | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: GBL SecType: FUT Exchange: DTB Currency: | 2013-05-08 18:54:18 Subscribing to symbol: GBL SecType: FUT Exchange: DTB Currency: | 2013-05-08 18:54:18 HD Request # 1 - Downloading Intraday chart data for GBL-201306-DTB to the file GBL-201306-DTB.scid. Service: ib | 2013-05-08 18:54:18 HD Request # 1 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:18 HD Request # 1 - Requesting a total of 0 days and 4818 seconds. | 2013-05-08 18:54:18 HD Request # 1 - IB Backfill - Seconds requested: 4818. Seconds Remaining: 0. | 2013-05-08 18:54:18 HD Request # 1 - Requesting 4818 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:18 for GBL-201306-DTB | 2013-05-08 18:54:18 Starting updates for: $TICK | 2013-05-08 18:54:18 SC Index Data: Connecting to the market data server. | 2013-05-08 18:54:18 Using server: ds4.sierracharts.com, port 443 | 2013-05-08 18:54:18 SC Index Data - Local market data port: 0 | 2013-05-08 18:54:18 Starting updates for: INDU-I-NYSE | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: INDU SecType: IND Exchange: NYSE Currency: | 2013-05-08 18:54:18 Subscribing to symbol: INDU SecType: IND Exchange: NYSE Currency: | 2013-05-08 18:54:18 Starting updates for: NG-201306-NYMEX | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-08 18:54:18 Subscribing to symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-08 18:54:18 Starting updates for: YM-201306-ECBOT | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: YM SecType: FUT Exchange: ECBOT Currency: | 2013-05-08 18:54:18 Subscribing to symbol: YM SecType: FUT Exchange: ECBOT Currency: | 2013-05-08 18:54:18 Starting updates for: CAC40-201305-MONEP | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: CAC40 SecType: FUT Exchange: MONEP Currency: | 2013-05-08 18:54:18 Subscribing to symbol: CAC40 SecType: FUT Exchange: MONEP Currency: | 2013-05-08 18:54:18 Starting updates for: EUR-201306-GLOBEX | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: EUR SecType: FUT Exchange: GLOBEX Currency: | 2013-05-08 18:54:18 Subscribing to symbol: EUR SecType: FUT Exchange: GLOBEX Currency: | 2013-05-08 18:54:18 Starting updates for: ES-201306-GLOBEX | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2013-05-08 18:54:18 Subscribing to symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2013-05-08 18:54:18 Starting updates for: EUR.USD-CASH-IDEALPRO | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: EUR.USD SecType: CASH Exchange: IDEALPRO Currency: USD | 2013-05-08 18:54:18 Subscribing to symbol: EUR.USD SecType: CASH Exchange: IDEALPRO Currency: USD | 2013-05-08 18:54:18 Starting updates for: cac40-I-monep | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: cac40 SecType: IND Exchange: monep Currency: | 2013-05-08 18:54:18 Subscribing to symbol: cac40 SecType: IND Exchange: monep Currency: | 2013-05-08 18:54:18 Starting updates for: GC-201306-NYMEX | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: GC SecType: FUT Exchange: NYMEX Currency: | 2013-05-08 18:54:18 Subscribing to symbol: GC SecType: FUT Exchange: NYMEX Currency: | 2013-05-08 18:54:18 Starting updates for: ZN-201306-ECBOT | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: ZN SecType: FUT Exchange: ECBOT Currency: | 2013-05-08 18:54:18 Subscribing to symbol: ZN SecType: FUT Exchange: ECBOT Currency: | 2013-05-08 18:54:18 Starting updates for: AAPL | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: AAPL SecType: STK Exchange: SMART Currency: USD | 2013-05-08 18:54:18 Subscribing to symbol: AAPL SecType: STK Exchange: SMART Currency: USD | 2013-05-08 18:54:18 Starting updates for: ZB-201306-ECBOT | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: ZB SecType: FUT Exchange: ECBOT Currency: | 2013-05-08 18:54:18 Subscribing to symbol: ZB SecType: FUT Exchange: ECBOT Currency: | 2013-05-08 18:54:18 Starting updates for: DAX-I-DTB | 2013-05-08 18:54:18 Subscribing to real-time True Data for symbol: DAX SecType: IND Exchange: DTB Currency: | 2013-05-08 18:54:18 Subscribing to symbol: DAX SecType: IND Exchange: DTB Currency: | 2013-05-08 18:54:18 HD Request # 1 - Processing historical data message from TWS | 2013-05-08 18:54:18 HD Request # 1 - Receiving Intraday data for GBL-201306-DTB starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:18 HD Request # 1 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:18 HD Request # 1 - Received 21 records and wrote 1 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:00. | 2013-05-08 18:54:18 Message from IB: Requête en temps réel invalide:No market data permissions for DTB IND. IB Error Code: 420. Request ID: 825711. | 2013-05-08 18:54:18 The network socket is connected. | 2013-05-08 18:54:19 SC Index Data: Connected to market data server. Now authorizing. | 2013-05-08 18:54:19 SC Index Data: Connected. | 2013-05-08 18:54:19 Restarting real-time data updates for symbol: $TICK | 2013-05-08 18:54:19 HD Request # 2 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: scsrv | 2013-05-08 18:54:20 HD Request # 2 - Starting date and time: 2013-05-08 18:54:09 | 2013-05-08 18:54:20 HD Request # 2 - Using server: ds5.sierracharts.com port 10049 | 2013-05-08 18:54:20 The network socket is connected. | 2013-05-08 18:54:20 HD Request # 2 - Requesting up to 90 days of Intraday data. | 2013-05-08 18:54:20 HD Request # 2 - Decompressing data. | 2013-05-08 18:54:20 HD Request # 2 - Receiving Intraday data for $TICK starting at 2013-05-08 18:54:09 | 2013-05-08 18:54:20 HD Request # 2 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:09 | 2013-05-08 18:54:20 Socket closed. No error. | 2013-05-08 18:54:20 HD Request # 2 - Received 19 records from 2013-05-08 18:54:09 to 2013-05-08 18:54:27 (18.0 seconds) and wrote 19 records for $TICK | 2013-05-08 18:54:20 HD Request # 2 - Intraday download COMPLETE for $TICK | 2013-05-08 18:54:20 Real-time intraday chart data file updates started for $TICK | 2013-05-08 18:54:20 HD Request # 1 - Received 21 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:00 (10.0 minutes) and wrote 1 record for GBL-201306-DTB | 2013-05-08 18:54:20 HD Request # 1 - Intraday download COMPLETE for GBL-201306-DTB | 2013-05-08 18:54:20 Real-time intraday chart data file updates started for GBL-201306-DTB | 2013-05-08 18:54:20 HD Request # 4 - Downloading Intraday chart data for INDU-I-NYSE to the file INDU-I-NYSE.scid. Service: ib | 2013-05-08 18:54:20 HD Request # 4 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:20 HD Request # 4 - Requesting a total of 0 days and 4820 seconds. | 2013-05-08 18:54:20 HD Request # 4 - IB Backfill - Seconds requested: 4820. Seconds Remaining: 0. | 2013-05-08 18:54:20 HD Request # 4 - Requesting 4820 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:20 for INDU-I-NYSE | 2013-05-08 18:54:20 HD Request # 4 - Processing historical data message from TWS | 2013-05-08 18:54:21 HD Request # 4 - Receiving Intraday data for INDU-I-NYSE starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:21 HD Request # 4 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:21 HD Request # 4 - Received 21 records and wrote 1 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:00. | 2013-05-08 18:54:21 IB Trading service: Requesting Trade Positions for account: | 2013-05-08 18:54:23 IB Trading service: Received Trade Positions download end message. | 2013-05-08 18:54:23 HD Request # 4 - Received 21 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:00 (10.0 minutes) and wrote 1 record for INDU-I-NYSE | 2013-05-08 18:54:23 HD Request # 4 - Intraday download COMPLETE for INDU-I-NYSE | 2013-05-08 18:54:23 Real-time intraday chart data file updates started for INDU-I-NYSE | 2013-05-08 18:54:23 HD Request # 5 - Downloading Historical Daily chart data for INDU-I-NYSE. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:54:23 HD Request # 5 - Requesting 12 days of historical Daily data for INDU-I-NYSE with end date 2013-05-18 | 2013-05-08 18:54:23 HD Request # 5 - Processing historical data message from TWS | 2013-05-08 18:54:24 HD Request # 5 - Receiving historical Daily data for INDU-I-NYSE starting at 2013-05-02 | 2013-05-08 18:54:24 Writing historical daily data for INDU-I-NYSE to the file INDU-I-NYSE.dly | 2013-05-08 18:54:24 HD Request # 5 - Received 5 records and wrote 3 records from 2013-05-02 00:00:00 to 2013-05-08 00:00:00. | 2013-05-08 18:54:24 HD Request # 5 - Received 5 records from 2013-05-02 00:00:00 to 2013-05-08 00:00:00 (7.0 days) and wrote 3 records for INDU-I-NYSE | 2013-05-08 18:54:26 HD Request # 5 - Daily download COMPLETE for INDU-I-NYSE | 2013-05-08 18:54:26 HD Request # 6 - Downloading Intraday chart data for NG-201306-NYMEX to the file NG-201306-NYMEX.scid. Service: ib | 2013-05-08 18:54:26 HD Request # 6 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:26 HD Request # 6 - Requesting a total of 0 days and 4826 seconds. | 2013-05-08 18:54:26 HD Request # 6 - IB Backfill - Seconds requested: 4826. Seconds Remaining: 0. | 2013-05-08 18:54:26 HD Request # 6 - Requesting 4826 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:26 for NG-201306-NYMEX | 2013-05-08 18:54:26 HD Request # 6 - Processing historical data message from TWS | 2013-05-08 18:54:26 HD Request # 6 - Receiving Intraday data for NG-201306-NYMEX starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:26 HD Request # 6 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:26 HD Request # 6 - Received 21 records and wrote 1 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:00. | 2013-05-08 18:54:26 HD Request # 6 - Received 21 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:00 (10.0 minutes) and wrote 1 record for NG-201306-NYMEX | 2013-05-08 18:54:29 HD Request # 6 - Intraday download COMPLETE for NG-201306-NYMEX | 2013-05-08 18:54:29 Real-time intraday chart data file updates started for NG-201306-NYMEX | 2013-05-08 18:54:29 HD Request # 7 - Downloading Intraday chart data for YM-201306-ECBOT to the file YM-201306-ECBOT.scid. Service: ib | 2013-05-08 18:54:29 HD Request # 7 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:29 HD Request # 7 - Requesting a total of 0 days and 4829 seconds. | 2013-05-08 18:54:29 HD Request # 7 - IB Backfill - Seconds requested: 4829. Seconds Remaining: 0. | 2013-05-08 18:54:29 HD Request # 7 - Requesting 4829 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:29 for YM-201306-ECBOT | 2013-05-08 18:54:29 HD Request # 7 - Processing historical data message from TWS | 2013-05-08 18:54:29 HD Request # 7 - Receiving Intraday data for YM-201306-ECBOT starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:29 HD Request # 7 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:29 HD Request # 7 - Received 22 records and wrote 2 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30. | 2013-05-08 18:54:29 HD Request # 7 - Received 22 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30 (10.5 minutes) and wrote 2 records for YM-201306-ECBOT | 2013-05-08 18:54:32 HD Request # 7 - Intraday download COMPLETE for YM-201306-ECBOT | 2013-05-08 18:54:32 Real-time intraday chart data file updates started for YM-201306-ECBOT | 2013-05-08 18:54:32 HD Request # 8 - Downloading Intraday chart data for CAC40-201305-MONEP to the file CAC40-201305-MONEP.scid. Service: ib | 2013-05-08 18:54:32 HD Request # 8 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:32 HD Request # 8 - Requesting a total of 0 days and 4832 seconds. | 2013-05-08 18:54:32 HD Request # 8 - IB Backfill - Seconds requested: 4832. Seconds Remaining: 0. | 2013-05-08 18:54:32 HD Request # 8 - Requesting 4832 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:32 for CAC40-201305-MONEP | 2013-05-08 18:54:32 HD Request # 8 - Processing historical data message from TWS | 2013-05-08 18:54:32 HD Request # 8 - Receiving Intraday data for CAC40-201305-MONEP starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:32 HD Request # 8 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:32 HD Request # 8 - Received 22 records and wrote 2 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30. | 2013-05-08 18:54:32 HD Request # 8 - Received 22 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30 (10.5 minutes) and wrote 2 records for CAC40-201305-MONEP | 2013-05-08 18:54:34 HD Request # 8 - Intraday download COMPLETE for CAC40-201305-MONEP | 2013-05-08 18:54:34 Real-time intraday chart data file updates started for CAC40-201305-MONEP | 2013-05-08 18:54:34 HD Request # 9 - Downloading Intraday chart data for EUR-201306-GLOBEX to the file EUR-201306-GLOBEX.scid. Service: ib | 2013-05-08 18:54:34 HD Request # 9 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:34 HD Request # 9 - Requesting a total of 0 days and 4834 seconds. | 2013-05-08 18:54:34 HD Request # 9 - IB Backfill - Seconds requested: 4834. Seconds Remaining: 0. | 2013-05-08 18:54:34 HD Request # 9 - Requesting 4834 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:34 for EUR-201306-GLOBEX | 2013-05-08 18:54:34 HD Request # 9 - Processing historical data message from TWS | 2013-05-08 18:54:35 HD Request # 9 - Receiving Intraday data for EUR-201306-GLOBEX starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:35 HD Request # 9 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:35 HD Request # 9 - Received 22 records and wrote 2 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30. | 2013-05-08 18:54:35 HD Request # 9 - Received 22 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30 (10.5 minutes) and wrote 2 records for EUR-201306-GLOBEX | 2013-05-08 18:54:37 HD Request # 9 - Intraday download COMPLETE for EUR-201306-GLOBEX | 2013-05-08 18:54:37 Real-time intraday chart data file updates started for EUR-201306-GLOBEX | 2013-05-08 18:54:37 HD Request # 10 - Downloading Historical Daily chart data for YMM13. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:54:37 HD Request # 10 - Requesting 12 days of historical Daily data for YMM13 with end date 2013-05-18 | 2013-05-08 18:54:37 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 41. | 2013-05-08 18:54:37 Historical Data Symbol Error: YMM13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:54:37 HD Request # 10 - Error downloading historical Daily data for YMM13. The symbol was not found. | 2013-05-08 18:54:37 HD Request # 10 - Received 0 records and wrote 0 records for YMM13 | 2013-05-08 18:54:37 HD Request # 10 - Daily download COMPLETE for YMM13 | 2013-05-08 18:54:37 HD Request # 11 - Downloading Historical Daily chart data for CAC40-201305-MONEP. Starting date: 2013-05-07. Service: ib | 2013-05-08 18:54:37 HD Request # 11 - Requesting 11 days of historical Daily data for CAC40-201305-MONEP with end date 2013-05-18 | 2013-05-08 18:54:37 Message from IB: Aucune requête de données historiques retournée pour ticker id:41. IB Error Code: 366. Request ID: 41. | 2013-05-08 18:54:37 HD Request # 11 - Processing historical data message from TWS | 2013-05-08 18:54:37 HD Request # 11 - Receiving historical Daily data for CAC40-201305-MONEP starting at 2013-05-03 | 2013-05-08 18:54:37 Writing historical daily data for CAC40-201305-MONEP to the file CAC40-201305-MONEP.dly | 2013-05-08 18:54:37 HD Request # 11 - Received 4 records and wrote 2 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00. | 2013-05-08 18:54:37 HD Request # 11 - Received 4 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00 (6.0 days) and wrote 2 records for CAC40-201305-MONEP | 2013-05-08 18:54:40 HD Request # 11 - Daily download COMPLETE for CAC40-201305-MONEP | 2013-05-08 18:54:40 HD Request # 12 - Downloading Historical Daily chart data for ESM13. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:54:40 HD Request # 12 - Requesting 12 days of historical Daily data for ESM13 with end date 2013-05-18 | 2013-05-08 18:54:40 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 45. | 2013-05-08 18:54:40 Historical Data Symbol Error: ESM13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:54:40 HD Request # 12 - Error downloading historical Daily data for ESM13. The symbol was not found. | 2013-05-08 18:54:40 HD Request # 12 - Received 0 records and wrote 0 records for ESM13 | 2013-05-08 18:54:40 HD Request # 12 - Daily download COMPLETE for ESM13 | 2013-05-08 18:54:40 HD Request # 13 - Downloading Intraday chart data for ES-201306-GLOBEX to the file ES-201306-GLOBEX.scid. Service: ib | 2013-05-08 18:54:40 HD Request # 13 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:40 HD Request # 13 - Requesting a total of 0 days and 4840 seconds. | 2013-05-08 18:54:40 HD Request # 13 - IB Backfill - Seconds requested: 4840. Seconds Remaining: 0. | 2013-05-08 18:54:40 HD Request # 13 - Requesting 4840 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:40 for ES-201306-GLOBEX | 2013-05-08 18:54:40 Message from IB: Aucune requête de données historiques retournée pour ticker id:45. IB Error Code: 366. Request ID: 45. | 2013-05-08 18:54:40 HD Request # 13 - Processing historical data message from TWS | 2013-05-08 18:54:40 HD Request # 13 - Receiving Intraday data for ES-201306-GLOBEX starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:40 HD Request # 13 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:40 HD Request # 13 - Received 22 records and wrote 2 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30. | 2013-05-08 18:54:40 HD Request # 13 - Received 22 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30 (10.5 minutes) and wrote 2 records for ES-201306-GLOBEX | 2013-05-08 18:54:43 HD Request # 13 - Intraday download COMPLETE for ES-201306-GLOBEX | 2013-05-08 18:54:43 Real-time intraday chart data file updates started for ES-201306-GLOBEX | 2013-05-08 18:54:43 HD Request # 14 - Downloading Historical Daily chart data for GGM13. Starting date: 2013-05-03. Service: ib | 2013-05-08 18:54:43 HD Request # 14 - Requesting 15 days of historical Daily data for GGM13 with end date 2013-05-18 | 2013-05-08 18:54:43 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 49. | 2013-05-08 18:54:43 Historical Data Symbol Error: GGM13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:54:43 HD Request # 14 - Error downloading historical Daily data for GGM13. The symbol was not found. | 2013-05-08 18:54:43 HD Request # 14 - Received 0 records and wrote 0 records for GGM13 | 2013-05-08 18:54:43 HD Request # 14 - Daily download COMPLETE for GGM13 | 2013-05-08 18:54:43 HD Request # 15 - Downloading Intraday chart data for EUR.USD-CASH-IDEALPRO to the file EUR.USD-CASH-IDEALPRO.scid. Service: ib | 2013-05-08 18:54:43 HD Request # 15 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:43 HD Request # 15 - Requesting a total of 0 days and 4843 seconds. | 2013-05-08 18:54:43 HD Request # 15 - IB Backfill - Seconds requested: 4843. Seconds Remaining: 0. | 2013-05-08 18:54:43 HD Request # 15 - Requesting 4843 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:43 for EUR.USD-CASH-IDEALPRO | 2013-05-08 18:54:43 Message from IB: Aucune requête de données historiques retournée pour ticker id:49. IB Error Code: 366. Request ID: 49. | 2013-05-08 18:54:43 HD Request # 15 - Processing historical data message from TWS | 2013-05-08 18:54:43 HD Request # 15 - Receiving Intraday data for EUR.USD-CASH-IDEALPRO starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:43 HD Request # 15 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:43 HD Request # 15 - Received 22 records and wrote 2 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30. | 2013-05-08 18:54:43 HD Request # 15 - Received 22 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30 (10.5 minutes) and wrote 2 records for EUR.USD-CASH-IDEALPRO | 2013-05-08 18:54:46 HD Request # 15 - Intraday download COMPLETE for EUR.USD-CASH-IDEALPRO | 2013-05-08 18:54:46 Real-time intraday chart data file updates started for EUR.USD-CASH-IDEALPRO | 2013-05-08 18:54:46 HD Request # 16 - Downloading Historical Daily chart data for ^EURUSD. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:54:46 HD Request # 16 - Requesting 12 days of historical Daily data for ^EURUSD with end date 2013-05-18 | 2013-05-08 18:54:46 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 53. | 2013-05-08 18:54:46 Historical Data Symbol Error: ^EURUSD is unknown, unavailable, or improperly formatted. | 2013-05-08 18:54:46 HD Request # 16 - Error downloading historical Daily data for ^EURUSD. The symbol was not found. | 2013-05-08 18:54:46 HD Request # 16 - Received 0 records and wrote 0 records for ^EURUSD | 2013-05-08 18:54:46 HD Request # 16 - Daily download COMPLETE for ^EURUSD | 2013-05-08 18:54:46 HD Request # 17 - Downloading Historical Daily chart data for GBL-201306-DTB. Starting date: 2013-05-07. Service: ib | 2013-05-08 18:54:46 HD Request # 17 - Requesting 11 days of historical Daily data for GBL-201306-DTB with end date 2013-05-18 | 2013-05-08 18:54:46 Message from IB: Aucune requête de données historiques retournée pour ticker id:53. IB Error Code: 366. Request ID: 53. | 2013-05-08 18:54:46 HD Request # 17 - Processing historical data message from TWS | 2013-05-08 18:54:46 HD Request # 17 - Receiving historical Daily data for GBL-201306-DTB starting at 2013-05-03 | 2013-05-08 18:54:46 Writing historical daily data for GBL-201306-DTB to the file GBL-201306-DTB.dly | 2013-05-08 18:54:46 HD Request # 17 - Received 4 records and wrote 2 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00. | 2013-05-08 18:54:46 HD Request # 17 - Received 4 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00 (6.0 days) and wrote 2 records for GBL-201306-DTB | 2013-05-08 18:54:49 HD Request # 17 - Daily download COMPLETE for GBL-201306-DTB | 2013-05-08 18:54:49 HD Request # 18 - Downloading Intraday chart data for cac40-I-monep to the file cac40-I-monep.scid. Service: ib | 2013-05-08 18:54:49 HD Request # 18 - Starting date and time: 2013-05-08 17:29:55 | 2013-05-08 18:54:49 HD Request # 18 - Requesting a total of 0 days and 9894 seconds. | 2013-05-08 18:54:49 HD Request # 18 - IB Backfill - Seconds requested: 9894. Seconds Remaining: 0. | 2013-05-08 18:54:49 HD Request # 18 - Requesting 9894 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:49 for cac40-I-monep | 2013-05-08 18:54:49 HD Request # 18 - Processing historical data message from TWS | 2013-05-08 18:54:49 HD Request # 18 - Receiving Intraday data for cac40-I-monep starting at 2013-05-08 14:45:00 | 2013-05-08 18:54:49 HD Request # 18 - Received 330 records and wrote 0 records from 2013-05-08 14:45:00 to 2013-05-08 17:29:30. | 2013-05-08 18:54:49 HD Request # 18 - Received 330 records from 2013-05-08 14:45:00 to 2013-05-08 17:29:30 (2.7 hours) and wrote 0 records for cac40-I-monep | 2013-05-08 18:54:51 HD Request # 18 - Intraday download COMPLETE for cac40-I-monep | 2013-05-08 18:54:51 Real-time intraday chart data file updates started for cac40-I-monep | 2013-05-08 18:54:51 HD Request # 19 - Downloading Historical Daily chart data for E6M13. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:54:51 HD Request # 19 - Requesting 12 days of historical Daily data for E6M13 with end date 2013-05-18 | 2013-05-08 18:54:51 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 58. | 2013-05-08 18:54:52 Historical Data Symbol Error: E6M13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:54:52 HD Request # 19 - Error downloading historical Daily data for E6M13. The symbol was not found. | 2013-05-08 18:54:52 HD Request # 19 - Received 0 records and wrote 0 records for E6M13 | 2013-05-08 18:54:52 HD Request # 19 - Daily download COMPLETE for E6M13 | 2013-05-08 18:54:52 HD Request # 20 - Downloading Intraday chart data for GC-201306-NYMEX to the file GC-201306-NYMEX.scid. Service: ib | 2013-05-08 18:54:52 HD Request # 20 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:54:52 HD Request # 20 - Requesting a total of 0 days and 4852 seconds. | 2013-05-08 18:54:52 HD Request # 20 - IB Backfill - Seconds requested: 4852. Seconds Remaining: 0. | 2013-05-08 18:54:52 HD Request # 20 - Requesting 4852 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:04:52 for GC-201306-NYMEX | 2013-05-08 18:54:52 Message from IB: Aucune requête de données historiques retournée pour ticker id:58. IB Error Code: 366. Request ID: 58. | 2013-05-08 18:54:52 HD Request # 20 - Processing historical data message from TWS | 2013-05-08 18:54:52 HD Request # 20 - Receiving Intraday data for GC-201306-NYMEX starting at 2013-05-08 18:44:00 | 2013-05-08 18:54:52 HD Request # 20 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:54:52 HD Request # 20 - Received 22 records and wrote 2 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30. | 2013-05-08 18:54:52 HD Request # 20 - Received 22 records from 2013-05-08 18:44:00 to 2013-05-08 18:54:30 (10.5 minutes) and wrote 2 records for GC-201306-NYMEX | 2013-05-08 18:54:54 HD Request # 20 - Intraday download COMPLETE for GC-201306-NYMEX | 2013-05-08 18:54:54 Real-time intraday chart data file updates started for GC-201306-NYMEX | 2013-05-08 18:54:54 HD Request # 21 - Downloading Historical Daily chart data for ZN-201306-ECBOT. Starting date: 2013-05-07. Service: ib | 2013-05-08 18:54:54 HD Request # 21 - Requesting 11 days of historical Daily data for ZN-201306-ECBOT with end date 2013-05-18 | 2013-05-08 18:54:54 HD Request # 21 - Processing historical data message from TWS | 2013-05-08 18:54:55 HD Request # 21 - Receiving historical Daily data for ZN-201306-ECBOT starting at 2013-05-03 | 2013-05-08 18:54:55 Writing historical daily data for ZN-201306-ECBOT to the file ZN-201306-ECBOT.dly | 2013-05-08 18:54:55 HD Request # 21 - Received 4 records and wrote 2 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00. | 2013-05-08 18:54:55 HD Request # 21 - Received 4 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00 (6.0 days) and wrote 2 records for ZN-201306-ECBOT | 2013-05-08 18:54:57 HD Request # 21 - Daily download COMPLETE for ZN-201306-ECBOT | 2013-05-08 18:54:57 HD Request # 22 - Downloading Historical Daily chart data for EUR-201306-GLOBEX. Starting date: 2013-05-07. Service: ib | 2013-05-08 18:54:57 HD Request # 22 - Requesting 11 days of historical Daily data for EUR-201306-GLOBEX with end date 2013-05-18 | 2013-05-08 18:54:57 HD Request # 22 - Processing historical data message from TWS | 2013-05-08 18:54:57 HD Request # 22 - Receiving historical Daily data for EUR-201306-GLOBEX starting at 2013-05-03 | 2013-05-08 18:54:57 Writing historical daily data for EUR-201306-GLOBEX to the file EUR-201306-GLOBEX.dly | 2013-05-08 18:54:57 HD Request # 22 - Received 4 records and wrote 2 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00. | 2013-05-08 18:54:57 HD Request # 22 - Received 4 records from 2013-05-03 00:00:00 to 2013-05-08 00:00:00 (6.0 days) and wrote 2 records for EUR-201306-GLOBEX | 2013-05-08 18:55:00 HD Request # 22 - Daily download COMPLETE for EUR-201306-GLOBEX | 2013-05-08 18:55:00 HD Request # 23 - Downloading Historical Daily chart data for AAPL. Starting date: 2013-05-08. Service: ib | 2013-05-08 18:55:00 HD Request # 23 - Requesting 10 days of historical Daily data for AAPL with end date 2013-05-18 | 2013-05-08 18:55:00 HD Request # 23 - Processing historical data message from TWS | 2013-05-08 18:55:00 HD Request # 23 - Receiving historical Daily data for AAPL starting at 2013-05-07 | 2013-05-08 18:55:00 Writing historical daily data for AAPL to the file AAPL.dly | 2013-05-08 18:55:00 HD Request # 23 - Received 3 records and wrote 2 records from 2013-05-07 00:00:00 to 2013-05-09 00:00:00. | 2013-05-08 18:55:00 HD Request # 23 - Received 3 records from 2013-05-07 00:00:00 to 2013-05-09 00:00:00 (3.0 days) and wrote 2 records for AAPL | 2013-05-08 18:55:03 HD Request # 23 - Daily download COMPLETE for AAPL | 2013-05-08 18:55:03 HD Request # 24 - Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ib | 2013-05-08 18:55:03 HD Request # 24 - Starting date and time: 2013-05-08 18:54:00 | 2013-05-08 18:55:03 HD Request # 24 - Requesting a total of 0 days and 4863 seconds. | 2013-05-08 18:55:03 HD Request # 24 - IB Backfill - Seconds requested: 4863. Seconds Remaining: 0. | 2013-05-08 18:55:03 HD Request # 24 - Requesting 4863 Seconds of data at 30 secs with ending Date-Time at 2013-05-08 20:05:03 for AAPL | 2013-05-08 18:55:03 HD Request # 24 - Processing historical data message from TWS | 2013-05-08 18:55:03 HD Request # 24 - Receiving Intraday data for AAPL starting at 2013-05-08 18:44:00 | 2013-05-08 18:55:03 HD Request # 24 - Timestamp of first Intraday data file record written: 2013-05-08 18:54:00 | 2013-05-08 18:55:03 HD Request # 24 - Received 23 records and wrote 3 records from 2013-05-08 18:44:00 to 2013-05-08 18:55:00. | 2013-05-08 18:55:03 HD Request # 24 - Received 23 records from 2013-05-08 18:44:00 to 2013-05-08 18:55:00 (11.0 minutes) and wrote 3 records for AAPL | 2013-05-08 18:55:05 HD Request # 24 - Intraday download COMPLETE for AAPL | 2013-05-08 18:55:05 Real-time intraday chart data file updates started for AAPL | 2013-05-08 18:55:05 HD Request # 25 - Downloading Historical Daily chart data for ZBM13. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:55:05 HD Request # 25 - Requesting 12 days of historical Daily data for ZBM13 with end date 2013-05-18 | 2013-05-08 18:55:05 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 66. | 2013-05-08 18:55:06 Historical Data Symbol Error: ZBM13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:55:06 HD Request # 25 - Error downloading historical Daily data for ZBM13. The symbol was not found. | 2013-05-08 18:55:06 HD Request # 25 - Received 0 records and wrote 0 records for ZBM13 | 2013-05-08 18:55:06 HD Request # 25 - Daily download COMPLETE for ZBM13 | 2013-05-08 18:55:06 HD Request # 26 - Downloading Historical Daily chart data for DYY0. Starting date: 2013-05-03. Service: ib | 2013-05-08 18:55:06 HD Request # 26 - Requesting 15 days of historical Daily data for DYY0 with end date 2013-05-18 | 2013-05-08 18:55:06 Message from IB: Aucune requête de données historiques retournée pour ticker id:66. IB Error Code: 366. Request ID: 66. | 2013-05-08 18:55:06 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 69. | 2013-05-08 18:55:06 Historical Data Symbol Error: DYY0 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:55:06 HD Request # 26 - Error downloading historical Daily data for DYY0. The symbol was not found. | 2013-05-08 18:55:06 HD Request # 26 - Received 0 records and wrote 0 records for DYY0 | 2013-05-08 18:55:06 HD Request # 26 - Daily download COMPLETE for DYY0 | 2013-05-08 18:55:06 HD Request # 27 - Downloading Historical Daily chart data for GCM13. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:55:06 HD Request # 27 - Requesting 12 days of historical Daily data for GCM13 with end date 2013-05-18 | 2013-05-08 18:55:06 Message from IB: Aucune requête de données historiques retournée pour ticker id:69. IB Error Code: 366. Request ID: 69. | 2013-05-08 18:55:06 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 72. | 2013-05-08 18:55:06 Historical Data Symbol Error: GCM13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:55:06 HD Request # 27 - Error downloading historical Daily data for GCM13. The symbol was not found. | 2013-05-08 18:55:06 HD Request # 27 - Received 0 records and wrote 0 records for GCM13 | 2013-05-08 18:55:06 HD Request # 27 - Daily download COMPLETE for GCM13 | 2013-05-08 18:55:06 HD Request # 28 - Downloading Historical Daily chart data for $DOWI. Starting date: 2013-05-03. Service: ib | 2013-05-08 18:55:06 HD Request # 28 - Requesting 15 days of historical Daily data for $DOWI with end date 2013-05-18 | 2013-05-08 18:55:06 Message from IB: Aucune requête de données historiques retournée pour ticker id:72. IB Error Code: 366. Request ID: 72. | 2013-05-08 18:55:06 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 75. | 2013-05-08 18:55:06 Historical Data Symbol Error: $DOWI is unknown, unavailable, or improperly formatted. | 2013-05-08 18:55:06 HD Request # 28 - Error downloading historical Daily data for $DOWI. The symbol was not found. | 2013-05-08 18:55:06 HD Request # 28 - Received 0 records and wrote 0 records for $DOWI | 2013-05-08 18:55:06 HD Request # 28 - Daily download COMPLETE for $DOWI | 2013-05-08 18:55:06 HD Request # 29 - Downloading Historical Daily chart data for NGM13. Starting date: 2013-05-06. Service: ib | 2013-05-08 18:55:06 HD Request # 29 - Requesting 12 days of historical Daily data for NGM13 with end date 2013-05-18 | 2013-05-08 18:55:06 Message from IB: Aucune requête de données historiques retournée pour ticker id:75. IB Error Code: 366. Request ID: 75. | 2013-05-08 18:55:06 Message from IB: Aucune définition de titre trouvée pour cette requête. IB Error Code: 200. Request ID: 78. | 2013-05-08 18:55:06 Historical Data Symbol Error: NGM13 is unknown, unavailable, or improperly formatted. | 2013-05-08 18:55:06 HD Request # 29 - Error downloading historical Daily data for NGM13. The symbol was not found. | 2013-05-08 18:55:06 HD Request # 29 - Received 0 records and wrote 0 records for NGM13 | 2013-05-08 18:55:06 HD Request # 29 - Daily download COMPLETE for NGM13 | 2013-05-08 18:55:06 Message from IB: Aucune requête de données historiques retournée pour ticker id:78. IB Error Code: 366. Request ID: 78. | 2013-05-08 18:55:06 The chart image has been saved to: C:\SierraChart\Images\ES-201306-GLOBEX Daily #7 41402.7056.png | 2013-05-08 18:56:04 |
ES-201306-GLOBEX Daily #7 41402.7056.png / V - Attached On 2013-05-08 16:57:29 UTC - Size: 81.95 KB - 510 views |
[2013-05-08 17:06:08] |
You need to enable Global Settings >> Data/Trade Service Settings >> Historical Data Service Settings >> Use Sierra Chart Historical Data Service. Press OK twice. After this go to Edit >> Download Data For All Historical Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-08 17:13:55] |
User73873 - Posts: 14 |
Everything is ok! Thank you... |
