Date/Time: Thu, 28 Mar 2024 18:28:07 +0000
Display day session bars only for intraday chart
View Count: 1021
[2014-06-13 01:29:01] |
DamienBoyle - Posts: 7 |
Is there a way to get SC to automatically only display the day session bars, e.g. for ES 5min? I know I can set the day session hours in the chart settings. However I find it very confusing to do this when I am in a different time zone to the market and to UTC, when daylight savings occurs and when some market close at 15mins past the hour. It just blows my mind! In chart settings, under Advanced Settings, I checked Apply Intraday Session Times to Intraday Chart, but tis made no difference. Thanks in advance, Damien |
[2014-06-13 01:47:52] |
I think I have figured it out. It turns out you can set the chart time zone independent of the global settings time zone. So I set ES chart time zone to Chicago and set the chart times to the SP open out cry hours. Seems to be correct. Date Time Of Last Edit: 2014-06-13 01:48:32
[2014-06-13 02:29:53] |
Yes. You can do this. Let us know if you need more help.
