Date/Time: Tue, 23 Apr 2024 20:04:07 +0000
Point and Figure Open and Last
View Count: 959
[2014-06-12 04:37:32] |
OneMoreTick - Posts: 79 |
On the attached chart, I have "Last" set to ignore in the settings yet I'm still getting red marks on the PnF bars. Is this a bug or is this normal for PnF charts? I only want to see the Open of the bars as that's the only info I really need.
[2014-06-12 05:30:37] |
The Last mark of the bars is not drawn. The Last color is used for the Open mark for down bars.
[2014-06-12 14:18:44] |
Are you saying that in the settings "Open" is actually "Open for Up Bars" and "Last" is actually "Open for Down Bars?"
[2014-06-12 16:42:35] |
Yes. For coloring this is apparently how it works.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-12 16:42:52
