Date/Time: Fri, 29 Mar 2024 01:07:46 +0000
Tick-Level Data for Bitstamp/Bitfinex
View Count: 2102
[2014-06-11 19:03:03] |
btcdt95 - Posts: 8 |
Hi all, I've downloaded tick-level Bitstamp/Bitfinex exchange data from bitcoincharts.com but their data does not tell me in what order trades occur within a second. So, if 2 trades "X" and "Y" happen at 3:00:00 on 01/01/2014, one dataset lists X then Y and the same dataset (but downloaded at a different time) lists Y then X. So my questions are as follows: (1) Do you offer tick-by-tick data that shows the order in which the trades happened WITHIN a second? (2) Do you pull tick-by-tick data from a source other than bitcoincharts? Are you using the exchange order books or what? I need a 2nd source to compare to (besides bitcoincharts). (3) Do you make your data downloadable via CSV/another format to use with statistical software? Thank you! |
[2014-06-12 17:01:17] |
1. Yes. But we assume that the trades provided by the exchange where the data comes from, is in the proper order. We have no way to verify this. But we have no reason to think it is wrong either. So we do think it is correct. 2. The data comes direct from the exchanges. 3. The data can be exported. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ImportExport.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-12 17:01:24
