Date/Time: Tue, 23 Apr 2024 17:17:52 +0000
Crosshair on the Trading DOM?
View Count: 1260
[2014-06-09 16:50:09] |
User51760 - Posts: 108 |
Hello Support Team, is it be possible to add the option of using the crosshair's y-value (price) line in the trading DOM, so that the y-value line of the DOM would be reflected in a linked chart and vice versa (in global cursor mode)? Thank you for your consideration, Best, Chris |
[2014-06-12 17:34:26] |
This is not supported or planned.
[2014-06-12 18:26:53] |
Zosimus - Posts: 345 |
User51760, did you try using the Chart Dom ? When the Dom is on the Chart the Dom/Chart relationship is much more visual especially when using the CrossHair. http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ChartDOM |
