Date/Time: Sat, 20 Apr 2024 04:50:05 +0000
millisecond charting
View Count: 994
[2014-06-09 18:05:35] |
Individual ticks/trades stored by Sierra Chart do use millisecond timestamps, but Sierra Chart uses the milliseconds as a counter to create a unique timestamp for each trade.
[2014-06-10 16:36:57] |
The update frequency of a symbol is unrelated to millisecond timestamps. We are not quite sure what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
